Best engine for TF sea fury
Ive just perchased this kit and in the instuctions it states that this plane should not be over powered. they highly recommend using a .91 four stroke. I was planing to use a .120 four stroke. can some tell me which engine would be the best choice. this is my first scale war bird. but ive built and flown four different types of advance aerobats. would appreciate any advice or help.
I suspect like most WWII warbirds the Sea Fury will build a little tail heavy. If that is the case, it makes a bunch more sense to put a bigger/heavier engine up front. Much bette IMO to have more pony's up front than a pound or two of lead counter balance. that is just going along for the ride. I do not think the 120 four stroke would be too much engine, after all it is going to have a throttle, isn't it?
Vince
Vince
Engine size
Vince is right. I had to add about a pound of lead in the cowl of my DC Sea Fury. I was flying it with an FX61 engiine and its certainly not over powered. I just bought a Tiger Shark 75 for it.
My Feedback: (8)
TX
Sea Fury Power
I plan on using a YS 120 in mine. I put a 120 in all my 60 size warbirds - always makes them perform like the full scale bird. Anything less is too wimpy for my tastes. They handle the weight and power just fine. The throttle can always be pulled back, but if you have a smaller engine and the throttle pushed all the way forward, but need more power - there just ain't no more. No problem with a big 4 banger like the 120 - the ONLY way to fly.
Just my $.02 worth.
Regards, Les Morrow
Just my $.02 worth.
Regards, Les Morrow
BC, CANADA
That Saito .90 radial sure looks like it would fit in there quite nicely and don't forget that most warbirds can't hover or do torque rolls.
TT 120 for Sea Fury
I live in Colorado Springs (~6500 ft) and decided to get a TT 1.20 2s for my TF Sea Fury. The extra weight of the engine means no useless noseweight, and I have extra power for the altitude. (Small general-aviation planes sometimes can't get out of ground effect during the summer here!!)
I found what looks like a good in-cowl muffler specific to this engine at jtecrc dot com.
Haven't built it yet, so that's all I can say!
Patrick
[OOPS! Had to edit this. You would need to build REALLY light to use a .120 on this plane!]
Patrick
Sea Fury Spinner
Bob Holman sells a 4 1/16" spinner (for the Brian Taylor 81" Mossie) that looks like it would be a good fit for this plane. Certainly looks more accurate than most sport spinners, which are proportionally too long.
Patrick
Patrick
Hey, Edwin! Yes, it's me... I haven't started on the Sea Fury yet. I estimate another $600 to completion! Which may take a few months. I'm going to use Robart retracts, and their retractable tailwheel #122. It's supposed to be too small for the plane but it's the only one that looks like it'll retract backwards like the real thing.
My hand is completely recovered from last year's prop story, except for a funny-looking index fingernail.
I'm still working on the Zenith pattern plane. Should have it done in a short while. (I know... I've said that for about a year now.)
Email me and let me know how things are going.
Patrick
Patrick
