Zero decalage
Old 09-17-2007 | 10:58 AM
Default Zero decalage
I'm drawing plans for a zero to build this winter. The scale drawings show 1 1/2 degrees positive on the stab and 4.5 degrees pos on the wing compared to the thrust line. This leaves 3 degrees on the wing compared to the tail. Does this seem excessive? First zero build.
Old 09-17-2007 | 12:07 PM
Default RE: Zero decalage
check the drawing for a wing tip incidence or different airfoil.they sometimes use wasout like we do.
Old 09-17-2007 | 12:35 PM
The wing tip incidence shows the same as the tail (if it's accurate); this would mean 3deg washout.
