Question for TF P-51 builders >
Old 03-25-2003 | 02:09 AM
Default Question for TF P-51 builders
I am done skinning the bottom of my wing for the TF .60 sized P-51. I was wondering, do I cut the wing sheeting off flush with the center section that I already sheeted, or do I keep it on and let it bulge out? Thanks, not sure if you get what I'm saying, if there is confusion I will take a pic.
Alex
Old 03-25-2003 | 02:47 AM
rptrsn's Avatar
If I follow you correctly, you sheet over the center sheeting thats already installed. This is done to eliminate the need for glassing the center.
Ron
Old 03-25-2003 | 12:06 PM
the main skin is supposed to go over the first center layer- but it should not bulge out- the top of the center layer should be even with the bottom of the top layer. of course the main skin ends at the wing center.
ed
Old 03-25-2003 | 08:00 PM
Good thanks for the help. Did you just glue the main skin onto the center skin so it isn't loose and bulging out? Thanks
Alex
