Byron Corsair Build
#903
My Feedback: (118)
It is good to see this thread is still fairly active after all this time.
I have committed to buy a Byron Corsair from a gentleman. Everything is included, but needs a minor overhaul.
For any of you Byron Corsair gurus out there...I have a question. This Corsair was built without flaps as they can be a handful for some in the building process. My question is how much of a major operation would it be at this point to cut away the flaps and make them functional.
I know these birds will land fine without them, but it would look and function better. It is also better for resale if that day comes along.
Thanks for any assistance or advice.
BTW...I could also use a copy of the manual, plans, etc.
#904
My Feedback: (90)
Wing Spars not symetrical
Hi all, I've had this never been built Byron Corsair for several years now, it came with Robert 150s which I have sunk a few bu$k into (upgrades). I bought all for $700. At one point I had a Saito twin I was going to use, then kinda gave up on the project and put it all for sale. The Saito sold, but I could not sell the rest, even when I offered it for less than $500 (for ALL). Now I've decided to build it, I'm spending the winter at home in Michigan for the first time I retired due to coronavirus, so plenty of time to build. I will be building it with electric power, and have already converted the 150s to electric powered so I won't have to deal with air systems.
ANYWAY, I decided to replace some of the wood parts, including the wing spars, so purchased the plywood and traced over it with originals, screwing them in place so they wouldn't shift. After tracing the outlines, I flipped them over to check for symmetry: low and behold, there IS a lack of symmetry, on the front spar more than the rear, but nonetheless both. I've decided to cut them oversize, trial fit and trim as necessary.
#905
My Feedback: (65)
I do have digital copies of the manuals and drawings provided with the kit.
Scott
Here's my 1st Byron's Corsair in 2007 with the flaps down.
CorsairJock (01-08-2021)
#907
My Feedback: (118)
Here are some photos of my Byron Corsair that I picked up. It was built without flaps. However, the original builder did a nice job with the build. The retracts with retractable tail wheel work flawlessly. It came with the original Purr Power mount, 4.2 Sachs and the Byron prop hub. I have since remounted the engine and made a new prop hub to use a standard prop. It is now ready for test running of the engine. However at 35 degrees, I'm not willing to play outside at the moment.
This would not have been my first choice of a paint scheme, but I'm not changing it at the moment. Most warbird guys won't like it. It should look good in the air anyway.
#908
My Feedback: (118)
I have just test run the engine. This 4.2 is a beautiful beast. It runs great. Smooth idle, transition, and powerful. All of the retracts and servos work fine as they should.
I have determined that I need to downsize and reduce my inventory of aircraft.
I will consider selling it for a reasonable offer.
It was not built with flaps, but that could be taken care of if you plan to repaint it. It comes with the original Byron prop and hub. Currently it has the standard prop hub and the single bolt adapter. It also has a full completed cockpit kit and sliding canopy. Overall it is a nicely built plane.
If you wish to make an offer, please keep a few things in mind.
1. Just he engine and retracts are it great condition and worth a fair price.
2. I prefer not to ship, but will deliver or meet at a reasonable distance.
Also willing to deliver to Atlanta Hobby Swap this month or Dayton Swap in April.
#910
My Feedback: (36)
MA
Agree not the best motor for the plane. I used a DA-85 for my build and it was an excellent choice for the plane. Still needed a little nose weight (8 oz) but not too much compared to other builds that I have seen.
#912
My Feedback: (36)
MA
Looks like it is already cut for flaps which is good as they are very effective for landing. I see that it still has the original plastic wheels. Mine did as well and failed on the first flight. I would highly recommend using aftermarket aluminum wheels.
GIJon (01-14-2022)
