Reload this Page >
SHOW YOUR DETAILED ARF WARBIRDS
Old 08-08-2008, 05:13 PM
  #76
phippsa3
phippsa3's Avatar
Default RE: SHOW YOUR DETAILED ARF WARBIRDS
Well done Navy0968.
Thats got to be the best artf bash i have seen so far. Brilliant.
Old 08-08-2008, 05:37 PM
  #77
Meschmidt
My Feedback: (15)
I used to think ARF's will hurt the true building and craftmanship of this hobby. But now there are more beautiful planes out there than ever. Here are my winter and summer completed projects this year. The P51 is a TF ARC, glassed with silk, and painted, powered by Husqvarna 4.4 . The AT6 is 82" Nitromodels ARF. Added panel lines, weathering. Powered by Poulan 42. Keep em' coming! Paul
ID:	1006897   Click image for larger version
Old 08-08-2008, 06:00 PM
  #78
Navy0968
Thanks Phippsa3.
Old 08-08-2008, 09:19 PM
  #79
NJAIRSTRIKE
Navy0968 , That ARF is absolutly beautifull, It has to be the BEST ARF/KIT whatever you want to call it plane I have seen so far.
Old 08-08-2008, 10:59 PM
  #80
AirWizard
AirWizard's Avatar
I'll second that!!!!!!!!!!!!!!!!!!!!!!
Old 08-08-2008, 11:55 PM
  #81
Capt. Winters
My Feedback: (8)
edit
Old 08-09-2008, 12:03 AM
  #82
Navy0968
Wow guys, thanks, I am humbled given all the beautiful aircraft on this site.
Old 08-09-2008, 01:20 AM
  #83
scale dail
My Feedback: (8)
scale dail's Avatar
I''ll bite.
Here are a few pics of my bashed kyosho P-51. Had a build thread on it.
ID:	1007133   Click image for larger version
ID:	1007134   Click image for larger version
ID:	1007135   Click image for larger version
Old 08-09-2008, 10:05 AM
  #84
THESCALEMAN
kmp YT 109
ID:	1007279   Click image for larger version
Old 08-09-2008, 10:21 AM
  #85
THESCALEMAN
ground shots
ID:	1007283   Click image for larger version
ID:	1007284   Click image for larger version
Old 08-09-2008, 12:58 PM
  #86
NoFlaps
My Feedback: (131)
WOW !!!!
That is inspiring !
You're making me look like a slacker~
Seriously, that is great work NAVY0968 !
Old 08-09-2008, 04:48 PM
  #87
Navy0968
Thanks Noflaps.
Old 08-09-2008, 09:26 PM
  #88
ticketec
Here is my heavily kit bashed CMPro Fw-190.
SPE 40cc
Zinger 3 blade prop with custom hub
Hitec meatal geared servos through out
KMP 190 (spring airs) retracts and oleos
dual 6v 1700mah R/X packs
15.5Lbs
Just completed flights number 2 and 3 yesterday. absolute pu$$y cat to fly.
thanks
dave
ID:	1007621   Click image for larger version
ID:	1007622   Click image for larger version
ID:	1007623   Click image for larger version
ID:	1007624   Click image for larger version
ID:	1007625   Click image for larger version
ID:	1007626   Click image for larger version
Old 08-10-2008, 10:42 AM
  #89
dutch Jan Hermkens
dutch Jan Hermkens's Avatar
Hi guys,
I have upgraded my only and one ARF model to more scale; the CMPro Corsair. Engine Laser 240-V.
regards,
Jan
ID:	1008008   Click image for larger version
ID:	1008009   Click image for larger version
ID:	1008010   Click image for larger version
ID:	1008011   Click image for larger version
ID:	1008012   Click image for larger version
ID:	1008013   Click image for larger version
ID:	1008014   Click image for larger version
ID:	1008016   Click image for larger version
ID:	1008017   Click image for larger version
ID:	1008018   Click image for larger version
Old 08-10-2008, 01:10 PM
  #90
bladerunner1955
My Feedback: (72)
Electric Sky Shark ARF, P-40, 84"wing, 25 friggen pounds but flew GREAT!. Just got home from the field after the maiden, when my friend sends over the You Tube clips of it I'll stick them up on this page. I used a AXI 5345 motor on 12 cells swinging a 22/12 prop. They are 8000 mah packs and flew it for more then 7 mins for the first flight. Second flight was about 8 mins with plenty of power to go. It will be able to fly about 10 mins,if I can stand the stress. No, really flew nice, lands with flaps great. Sierra Giant Scale retracts hold it up off the ground and Darrells retracts look as good as they work!
ID:	1008110   Click image for larger version
ID:	1008111   Click image for larger version
Old 08-11-2008, 03:28 PM
  #91
F-15 Flameout
F-15 Flameout's Avatar
This is the begining of my P-51 B conversion. It started life as a P-51 Strega from Will Hobbies. I had the plane and a P-51B conversion from Top Flite so I mergered them together. It wasn't a very easy job, the Strega was thinner and not as tall as the Top Flite version so I had to build up the air frame to fit. A ST 90 and Futaba 9 ch will provide plenty of power. The Puple and yellow version is what it began life as.
ID:	1009019   Click image for larger version
ID:	1009020   Click image for larger version
Old 08-11-2008, 05:27 PM
  #92
G-BBYB
G-BBYB's Avatar
YT Hurricane, electric conversion running on 12 A123 cells, 110A HV sintillon controller, and Tower Pro 5330 motor, radio JR
ID:	1009079   Click image for larger version
Old 08-11-2008, 07:20 PM
  #93
rcphotog
rcphotog's Avatar
carry on men.
Old 08-11-2008, 09:42 PM
  #94
scale dail
My Feedback: (8)
scale dail's Avatar
I think on the Corsair, the hinge line on the ailerons is taperd top and bottom with the hinge on the centerline. That is the way most ARF's come out of the box.
Just an amazing plane!
Old 08-11-2008, 11:46 PM
  #95
Navy0968
Rchotog & Scale dail,
Thanks for the kind words fellas and your concern Rchotog. The ailerons are fine, they have a double taper from the manufacturer and I decided not to alter them. I appreciate the heads-up though.
Old 05-15-2009, 08:01 PM
  #96
pilotorc4
pilotorc4's Avatar
WOW, I WANT TO CONGRATULATE YOU ON YOUR AT-6. IT CAME OUT REALLY NICE
Old 05-16-2009, 12:19 AM
  #97
Chad Veich
My Feedback: (60)
Can't say that I added a whole lot of detail but I did glass the flying surfaces and add the panel lines to my Thunder Tiger Sea Fury, as well as give it a new paint job. Just needs a clear coat and I can put it back together and go fly.
Old 05-16-2009, 03:06 AM
  #98
Scott Douglas
Scott Douglas's Avatar
Location: Hamilton, Scotland & La Roche Bernard, France
Navy0968, you are an inspiration! That is absolutely beautiful!!!
Here's my CMPro .50 size Corsair and my work in progress YT/KMPP38 (not one word from you Alan about how long I've been working on this!!)
regards
Scott
ID:	1199262   Click image for larger version
ID:	1199263   Click image for larger version
ID:	1199264   Click image for larger version
ID:	1199265   Click image for larger version
ID:	1199266   Click image for larger version
ID:	1199267   Click image for larger version
Old 09-27-2009, 03:03 PM
  #99
pilotorc4
pilotorc4's Avatar
I THOUGHT ABOUT BRINGING THIS THREAD BACK TO SEE IF ANYONE HAS COMPLETED ANY NEW ARF WARBIRDS, DON'T BE SHY AND SHOW YOUR ARFS.
Old 09-27-2009, 03:09 PM
  #100
lovetoflyguy
My Feedback: (139)
Here is my Easy Tiger TBM Avenger. The paint job was horrible on mine, so I decided to make it a sub-hunter. G-38, Century Jet retracts, and JR "stuff" inside.
PJ
ID:	1283519   Click image for larger version
