HELP to IDENTIFY this PLANE
My Feedback: (28)
RE: HELP to IDENTIFY this PLANE
What is the wingspan? Can you take a side profile picture? The obvious answer is that it''s a corsair - but I think your asking what manufacturer is the kit/ARF, right? You know it''s simple to calculate the CG for yourself, some kits/ARFs have incorrect CG information.
Mike
Mike
My Feedback: (-1)
KY
I would like to know the maufacturer...
it is not an ARF... someone built this bird. on the inside someone has identified each part in there own hand writting..
so I know its a KIT.. its actually an older one
the fusealage is very narrow so its not to scale looking I thought it would be a FUN SCALE....
CORSAIR yes thats the obvious.. lol.
the CG I figured to be about 20 to 30 % from the leading edge next to the fuse.
I balanced it there first.... which puts it about 2 and half inches back... since the wing width is only 12inches.
THE WING SPAN is 61 inches and all ready to fly it only weights in at 5 pds 5 onz.
I put a OS .46 FX abc on the nose I guess I will use a 11x5 prop for the first flight
I have a three bladed prop as well.... the kind that are found on the EVO''s
I want to fly this thing first with the APC 11x5 then experament from there....
I hope I answered all questions ....
but as far as more pics they will have to come later since I am at work.. THANKS AGAIN Ron
Look like the Great Planes Corsair to me.. I haven't seen the Top Flight Red Box kit.
http://www.greatplanes.com/airplanes/gpma0177.html
I have a GP .40 size corsair in the garage..
It looks the same.. 2 piece cowl (front and back sections)
Flat sides, no retracts.. (can't do it without hacking the main spar in half)
Well now that I look close I see a few odd things on the tail that may change my mind..
One thing is the rudder.. the GP kit has a counter balanced rudder set forward of the elevators..
This looks like the rudder is back even with them and has a straight hinge line to the top.
My Feedback: (-1)
KY
SScherin
I honestly don't think that its a great planes WOW it does look close I will tell ya that ..
but knowing how the wood looks in side and on the fuse WOW the fuse is not SHEETED......
its a laser cut with lightning wholes down the sides....
Thanks so much for the web sight.
Unless now. unless that I have a NEWER Version I dont
KNOW.????
KNOW.????
My Feedback: (-1)
KY
I went back to the websight again and looked at the MANUAL
the wingtips on the GREAT PLANES version has a balsa block that you have
to SAND to shape on my plane the Wing tips are built up. again some
similiarities but not the same...
My Feedback: (-1)
KY
YOU ARE CORRECT I found this websight http://webpages.charter.net/rcfu/Kit...MWCorsair.html
THANKS so much
now I know what I have..
and I did install an OS-46 in mine and I mounted the battery in the same place as the websight stated.
ONLY thing I flew this bird last night and OMG
it was so Sencative to the touch I feel that I had put to much control throw into the Ailerons
This bird snapped on me while banking to the right I had to fly her Inverted to recover
So I guess I will dial in less Control Throw and try her again when Weather permitts.
THANKS AGAIN GUYS..
THANKS so much
THANKS AGAIN GUYS..
