oh crap, another
oh crap, another
Saturday, I put a maiden on my 7th scale topflight p-51d ARF. I had rebuilt it after a friend crashed it cause the engine quit and hit power lines, he gave me the airplane, took me 2 weeks to get it done. I went and bought all new servos, a nd=ew D.A. 50 for it and then monokote, glue and all those little thing, I recken aout a grand invested. My first flight was a little squirly, my first war bird flight, only flew about 6 minuts, the engine being new was really burbly, did not trust it to run, landed for a few hours, flew other stuff, all going good, leaned the engine, fueled it up and went again, had another 6 minte flight. I landed, leaned it, and took off again and that would be the last take off it would ever have,
I was on the third minute and attemted the first roll, I used no elevator, keep the stress of of it, even know I know there was noting wrong, it was slow smooth roll. I came around and did it again, 4th minute of flight, about 300ft off the ground, upside down, the wing just as gracfully a could be, came off. I just went to another world holding my transmitter watching the lawn darn fly straight for awhile, I was still trying to fly it and land it on its side with elevater and rudder, it did hit about 70 degree angle, anly lost about 90 dollars, the airplane was free, just glue, monokote, 2 switches, and wood is all I lost, the engine was not hurt, the wing came down, did not hurt it.
After inspection, it was found that the pins at the front of the wong were not glued from factory, we looked thru the book, did not see where it said to do this, they had came out the front, and the plstics bolts could not hold the wong in with the heavy fuse hanging under neath. It sheard the heads of the bolts, id till have it if it had metal bolts, so if you have plastic, id change to metal bolts. I don't have pics or vids, so sad.
RE: oh crap, another
ORIGINAL: R/CBOONE72
Sorry for your loss my friend,
So, a DA 50 in a 1/7 scale, huh?
300 feet high and an angle of 70 degree, this accumulates to (no wing) about 50mph.
DA 50
Spinner for P51
$30
Propeller
$30
…looks like you are more out the pocket.
Besides, a small advice here – sent the 50 in to desert aircraft and they will check this engine if there are any damage. This service is pretty much free and worth the wait (8 to 10 days)
Happy landings
G-Pete
venom i fly at woodstock airport you must fly at the industrial park in killingly
used to fly there field is too small for my planes now i also know a lot of the guys from that club i might already know you lol
Jesse Russell
Jesse Russell
MI
i want to know why my comment was deleted on this thread. I simply said if you dont know to epoxy the wing mount dowls in the wing then you should not be flying this airplane. Bax what was wrong with that comment. THe arf generation cannot repair anything its well ill order a new wing. This hobby is going downhill and craftsmanship is becoming non existant.
also how can you have a DA engine in a 1/7 p-51. ? arf kits do not include plans or ant templates for repair thats so you buy a new wing instead of fixing what you have
ORIGINAL: timothy thompson
And I fail to understand why builders are so threatened by the ARF movement. There will ALWAYS be craftsman who are willing to kit-build and scratch-build, no matter how many ARFs are available on the market.
