Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
#3026
I am getting ready to start this build, I ordered the eflite retracts but I don't know what struts to use. also am planning to use a DLE20ra but I also have a pumped os120 4stroke that I could use whats everyones thoughts on these engine choices?
#3028
I will use the DLE . I would sure like some advice about different modifications tha you (every one who has this model) think should be done as I do the build. I realize that the topics and advice are already in this forum, but the posts span seven years and many pages!
#3029
My Feedback: (14)
Just be sure to reinforce the landing gear mounts in the wing. You should also put in some baffles to force all the cooling air through the engine fins and to keep the muffler heat off of the carb. Look at post #2714 and you can see what I did. If you want some nicer decals you should see Callie Graphics http://www.callie-graphics.com/
#3031
According to Robart rhe struts are #653L and R.
3/8" diameter LH Offset RoboStrut for a 3" - 3 1/4" Wheel (each)
http://robart.com/collections/gear-finder-top-flite-p-51-mustang-60/products/3-8-dia-lh-offset-robostrut-3-3-1-4-wheel
#3034
3-1/2 "wheels will be the max you can get in the stock wells. Also suggest that if you go with Robart wheels that you get the inserts for them as they will flatten out under the weight of the plane. The DLE will be a tight fit with the stock mount but it will work, you may want to go with another. I used a Dubro anti vibration mount only because I had it but it required redrilling the mounting holes in the firewall. Most definitely want to beef up the gear mounts as others have said.
#3039
I am with or170b on this one I will probably go with the eflite retract units and robart struts. Can we use the robostruts and if so which ones off the robart site?
Many have said that we will need to make adjustments to the length of the robart struts. how do you do that? I am presuming that they are longer than the specified fitment for length and they will need cutting so that the wheel and strut fit into the space of the well? how do the struts fit into the actuators of the undercarriage motors is this pretty self explanitory when you get them?
for those who have fitted the eflite motors, how have you fitted them, are they easy to fit and what modifications will there be in order to fit them snuggly into place as some have mentioned that you need to trim some of the wood away in order to do this? I am presuming again these have control wires for the servo attachment, where and how have you hidden your wires in the wheel wells? There is no way any wiring can slot through the holes in the wing for the metal poles of the OE fitment that came with the kit so I was wondering how you have managed to hide the wiring.
I have two images here and i was thinking of drilling a hole through the wing spar at 90 degrees so that the wire could go through the wing and down along with the flap and aileron wires? can this be done with a 90 degree drill and bit?
#3040
#3041
my progress so far. I am creating the chrome effect finish on mine (yes I have been warned about losing it in the sky) but I was determined to create a mega looking version of this great model. The monokote is fairly forgiving stuff but I am no expert compared to the guys who originally covered the model in the factory. But it looks ok so far. The only other time I have ever covered a plane like this from scratch is with my ongoing Great Planes Pitts special project which has a custom Adidas livery see the last pic
as it came out of the box
one of the final wings covered and finished with servos in place
#3042
would these be any good, it has the remote actuator in the kit too?
http://www.ebay.co.uk/itm/3313333411...84.m1436.l2649
#3043
If I was in your shoes I would go for one of the Eurokit retracts. Much better quality offered at much better price. I've used them a lot in my models and they work flawlessly with a lot of punishment in their use.http://www.eurokitshop.it/en/
#3044
The 60 size tf 51's are designed to use different retracts than the ones you are refering to.
#3045
My Feedback: (17)
The struts you need are the 653R and 653L. They will both need to be cut to length with a saw or rotary cutter. They come with a knurled insert that is tapped into the hollow strut after they have been cut to length. Follow the instructions that come with the struts. The wing will need to be slightly modified for the retracts and struts to fit properly, once you have all the components together you will see what needs to be done.
The struts referenced on the e-bay site are too big, they are for the giant scale Mustang. You will need decals for a 1/7th scale Mustang.
#3048
I have been working on fitting E-flite electrics into a wing that I am rebuilding. The stock retract struts have a 5 degree bend in them I guess to give the gear more forward angle. I cut a piece of 3/16" strut wire and gave it a little bend. This is what attaches the robart strut to the retract unit. The 5mm wire from the E-flights is too big to fit into the robart insert at the end of the oleo but I suppose it could be drilled out if you wanted to use the E-flite wire. Anyway, I still don't have them quite dialed in yet, but they look like they'll function pretty well.
#3049
many many thanks for taking the time to share your wealth of knowledge and knowhow on this, I very much appreciate it. Excuse my ignorance, but what is the wire for going through the metal pole? what does it do? I am also presuming that the only way to get the servo wires sorted is to run them along the inner surface of the flat part of the wing and make a hole in the inner flat bulkhead part of the wheel well where both wings are ultimately be glued and joined together? is there another way around this?
Does anyone know where the cheapest place is on the net to get the Eflite retract motors, robart struts and 3 1/4 or 3 1/2 sized robart wheels from?
#3050
My Feedback: (17)
As for the routing of the lead for the retract motor, you are correct, you will need to run it through the wing, enlarging a few holes as you go, and bring it out where the mechanical retract servo would mount.
Occasionally you can find an individual willing to sell a pair of the e-flite's for less than retail price but the best place to get a new, off the shelf, set is through Horizon or e bay.
http://www.horizonhobby.com/60---120...etract-eflg500
For the struts, same thing, maybe Tower or another online retailer.
http://www3.towerhobbies.com/cgi-bin...&I=LXES70&P=SM
http://www3.towerhobbies.com/cgi-bin...&I=LXES71&P=SM
The Tower price at this time is the cheapest that I can find.
The wheels will have to be the 3 3/4".
http://www3.towerhobbies.com/cgi-bin...&I=LXES44&P=SM
To go with a 3 1/2" wheel you will need these struts.
http://www3.towerhobbies.com/cgi-bin...&I=LXMRP2&P=SM
http://www3.towerhobbies.com/cgi-bin...&I=LXMRP3&P=SM
However, 3 1/2" wheels will require the wheel wells to be enlarged.
