Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
#1976
MD
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
Hi everyone!!!!
I recently purchase the mustang and started building and adding the robart retracts with robostruts. I am also adding functional gear doors as well. Ill post pics of my progress. The trimming of the retract rails was a pain to get the robart 510RS retracts to fit so the struts are flush when retracted. I'm going to be using the sonictronic hinge kit for the gear doors. so far the progress is going fairly smooth.
#1977
MD
here is an update to the gear doors. got them flush with the wing skins. Getting wheels and more hardware in the mail today. Ill update install pics soon
#1978
Great work Badazz.
I am also in the process of completing this P-51 60 size kit built that I got. THis one is covered with the Glamorous Glen scheme. My TF AT-6 does not have support in the air so this one has be be finished soon. Just have to figure out what engine to put. OS 91FS, OS120FS, or a recently acquired an OS160FXi that I could install a 4 blade prop (15.5x12x4)like I did in my previous P-51 with an OS200FS.
So, we are going to have an Airplane of the world event at the end of June, Perhaps we could fly these in formation!
Ton2di
Ton2di
#1979
CO
I have a 125 saito in mine and she fly's with authority, fun to fly. The 91 I have seen and fly's barley scale. If I remember the OS120 is pumped and would kick it up a notch. Of course if you want to save some money I like the DLE20 with the wrap around, and get rid of the mess of nitro. I love 4 stroke's but have several gas motors and like the clean'er burn, economy to run, generally less expensive. But I believe you would be happier with the 120 if you stay with those choices. Great Warbird to fly.
#1980
Springer,
Yes the OS120FSIII is the best option for me now, but the biggest prop I was able to use with this engine is an apc 14x10/15x8. The 160fxi on the other hand, can swing a 17x12/16x14 apc or the 15.5x12 4 blade that I already have. With this set up the ME 109's/FW 190's will have a hard time catching it!
Plus the 160FXi sits perfectly in the nose (34 oz. only with the header). The only problem I have is the noise. It has a header right now and it sounds so loud without a pipe (it would run without it because this engine uses a pressurized line to the tank so I do not need a vent line from the muffler). Well, it's either this or the 120.
Ton2di
Ton2di
#1981
Good weather today, and I'm taking my to the field.
Went from a 75AX to a 95AX, and she really performs well. Haven't had a chance to completely get used to it yet as the bad weather moved in early last fall.
#1982
MD
ORIGINAL: ton2di
Great work Badazz.
Ton2di
Great work Badazz.
Ton2di
Nice work on the gear doors Ton2di!!!!! love the Glamorous glen scheme too. yeah man we gotta get together sometime and do some flying!!
#1983
MD
Hey Ton2di how are you getting the gear doors to work? The spring function on the sonic tronic kit is not all that reliable. I'm thinking about a sequencer with a servo to get this to work
#1984
I will try to post some pics of the installation. It has a bell crank mechanism that it linked to the main air valve.
#1986
Kelly, I have found the 16-8 two blade to be best with the DLE 20. I'm getting about 8,500 rpm with the compact J-Tec pitts muffler. I got to fly it this week end. Finally had some good weather. I can't get over how well this thing flys with the DLE. The only problem was occassional miss at full throttle and rought sounding at mid range. However a change of spark plug seemed to have fixed it. Mine is the one in RAAF colors. I have over 200 flights on this airplane.
#1987
Kelly,
RBean is correct. The 16x8 is a good prop for the DLE 20.... but, if you want more speed then you would want to get an APC 15x10. A club member has it in his 60 size P-51 and it is so fast (around 8,300 rpms-ground).
Tony
Tony
#1988
Go to to the DLE thread. Xoar 17x6 works great. I have one on 3 planes now, my most recent the TFP-40 arf. Yeh baby!
#1989
MD
ORIGINAL: ton2di
#1992
Ok, so I had the Hangar 9 Blue Nose and it tip stalled on the maiden and was a total loss. Should I get this Top Flite to replace it and put the DL 20 in it?
R/C Foolish
R/C Foolish
#1993
R/C Foolish,
The H-9 P51 is heavy when assembled based on the reported weight here compared to the TF P-51... maybe part of the reason why it tip stalled on take off. Besides, a lot of people are complaining about how violently it snaps on turns. So if you really like P-51's then this TF 60 is great for you. Lots of happy owners here!!!
Tony
Tony
#1994
MD
ORIGINAL: Mustang Fever
badazz:
What brand of hinges are those on the inner doors, and where did you get them?
badazz:
they are the sonic tronic hinges. I ended up getting there gear door kit for this model. here is the link
http://sonictronics.com/xcart/home.php?cat=321
gear door kit
http://sonictronics.com/xcart/home.php?cat=378
#1995
My Top Flite Mustang flies great with a DLE 20. Weights 11 lbs but tip stalls are not a problem. It will stall and roll to the left, but does not snap over. Also with flaps down it slows down nice. I suppose you could tip stall the thing, but you would have to work at it. Like take off too slow and pull the nose up. But with a DLE 20 if you used lots of right rudder, you could probably power out of it. Its not a sports plane where you can just hit the throttle and pull up on the stick and go straight up. On take off you need to let roll, let the tail come up and pick up a little speed. But for a RC warbird these planes fly really good. I land on the mains (wheel landings they used to call this) with the flaps. You can land three point with the flaps, but its flying very slow when it lands, so its easy to get too slow.
#1997
VA
Test flew mine yesterday. Glad I read the balance point everyone in here is using. I think mine would do better at 5". Take off was good and it only needed a few clicks of down and left. Flew like a pattern ship. I see I'm going to have to shim the retracts in the rear a bit. It wants to nose over landing on the mains. That even with holding a little up elevator. But overall a great flying model. Mine is powered with a Magnum 91fs. plenty of power.
#1998
Hi guys. I am just finishing up my mustang with a DLE20 up front. Does anybody know what prop adapter is good for this engine and spinner? The one which comes with the kit doesn't fit the prop shaft.
Thanks!
#2000
Here are some picture of Mustang in the air. RAAF Italy 1945 Scheme. DLE 20, Robart retracts and struts.
