MIG-3 1/5 full composite
#52
RE: MIG-3 1/5 full composite
Rich,thank you actually this is the real web http://fokkerc.flugmodel.net/ in new place server of one very good guy Sverrir from Iceland
at-6 ,I know this foil ,but I have 30 kg . foil from other place thank's
#57
Here very interesting Web with video of 3.5 meter model 160 cc engine ,radio Graupner MC 19 ,baterie 6 V / 4,5 A,servo Hitec (11 kg)
http://www.rcmodely.cz/RCM_2_08_clanek08.htm
#65
As I saw is a TOP secret
I'll use something like foam ,but have much glass inside in the material .I will cut it with hobby knife and then sandpaper.
#68
.... and is thiner/gasoline resistant ....
I use small pieces recovered from metal wall insulatons ( those modern technology thin walls having a foam-type core sheeted with waved steel plates ).It's great advantage is it's verry easy to cut and sand.
It's like dense foam but the chemical composition is diferent.
#69
Bill ,the material is steady for acetone and other diluents ,is solid like a balsa and light like foam when I scrub it I can make it lake a glass
dvimi ,what is the name of your material ?
#75
Yes Jerry ,this is the reason to like and buiold this airpolane look like racer or old car with long muzzle
The the reason of long nose of Mis 3 is the bog engine ,the same engine like Il 2
