Charlie Kellogg's TBM Avenger Build
#2477
My Feedback: (35)
It has numatic cylinders but I'm going to replace them with electric ones. The avenger wasn't originally designed with folding wings, the guy who built it did all the work. I'm going to go thought it to make sure everything is structurally sound.
#2479
My Feedback: (15)
Larry
Try this first.
Go to bottom of this Quick Reply Box ---- Click On - GO ADVANCED
2nd - Click - MANAGE ATTACHMENTS
3rd - Upper Right - Click On - ADD FILES (Bottom of Screen)
4th - Use - SELECT FILES Button
5th - Click DONE (lower right corner)
6th - Submit Reply
Try this first.
6th - Submit Reply
#2483
Chic,
No problem would never give up on you....
As soon as I get the 2 canopy frames recut and fitted I will go back to the Avenger..... have to remove the coverite on the bottom of the horiz stabilizer as the paint crazed. Need to do it early in the AM before the garage temps get over 90
Let's hope I can remember how I did it
#2484
Okay guys,
A little cooler today, started stripping the covering off the bottom of the elevators. Guess it was a bad Idea
Hope to have them recovered by Thursday as I am also working on the Trojan.... my A D D isn't helping
#2485
Okay so here's an update.....
Got 1 half of the elevator recovered yesterday, should have just did the bottom of them in monocoat from the beginning but who knew.
Will cover the 2nd one today and try to put the adjusting screws back into the air valves so I can turn it over and start working on the servos
Oh, I forgot, I have to reinstall one of the inboard flaps that mysteriously detached itself from the airframe, just glad it didn't happen on the maiden
#2486
My Feedback: (15)
OK, OK - For at least the 30th plus time, I am back to work on the Avenger. Redoing the stitches on the elevators/rudder and eventually ailerons. After viewing the actual Avenger, I see where my initial stitches are completely wrong. The photos are not correct therefore, I removed them. Working on more scale like stitching, more round than elongated. Can't believe it is taking me this long to build/finish this model, but I will not quit. Chic
#2487
Chic,
Nice work, looks awesome...
BTW, can you let me know what air valves you are going to use for the gear and bomb bay doors, we used Robarts and the screws backed out when we maiden flew the plane
Off to work soon, figuring it will be WAY too hot in the garage when I get home at 12:30, not looking good this week, tomorrow 101, Tues - Wed 105 yuck
Larry
Larry
#2489
My Feedback: (15)
Charles Kellogg's TBM Avenger Build
OK, I stripped the stupid dumba** looking stitching and pink taping I did on the rudder. The stitching was "WAY TOOOO LARGE and WAY OUT OF SCALE". Didn't understand how I could miss that silly error. I certainly resized and re-evaluated after closely reviewing many photos of the rudder and especially the closeness of the stitching on the Avenger rudder, These photos are raw and once primered should look great.
#2493
Chic,
Nice work, looks like it was very tedious.
Almost have the flap fixed on the Avenger, hopefully by Wednesday since I have to do it early in the AM and I'm working today and tomorrow
And you won't believe this but the throws for the Avenger are not in the build sheets they are on the plans, was checking something out and noticed them... tough to get old and feeble
Best to Shirley
BTW, it is going to be a balmy 105 here today...ouch
Larry
Best to Shirley
Larry
#2495
My Feedback: (15)
Rudder Control. Using a method a friend on RCScalebuilder was going to use on his Avenger. The grooved plastic wheel has a screw in the back to secure the pull/pull cable, similar to the full scale Avenger rudder system. The small square pieces on the bottom of the sides and secured to the wheel, help to secure and maintain the cable onto the wheel, again, similar to the full scale as can slightly be seen in post #2492. Glad to be working again. Chic
