Reload this Page >
NOSEN P-51 (not).. MY OWN GIANT PLAN BUILD
Old 01-25-2010, 02:03 PM
  #451
rcwarbirdbuilder
My Feedback: (104)
rcwarbirdbuilder's Avatar
Default RE: Nosen P-51 (not). MY OWN GIANT PLAN BUILD
I have got the paint touched up and the engine is in, now to balance the airplane, other than some minor items it is done.
ID:	1364264   Click image for larger version
ID:	1364265   Click image for larger version
Old 01-25-2010, 02:57 PM
  #452
Slow Low
Slow Low's Avatar
...and what a beauty she is! The finished fit on that wing saddle is exceptional.
Old 01-25-2010, 07:56 PM
  #453
rcwarbirdbuilder
My Feedback: (104)
Slow Low- I hope you enjoyed the build thread and thank you for the nice compliment, George.
Old 02-01-2010, 04:18 AM
  #454
vskiwi
Hi from New Zealand, so I have the Nosen Kit which I picked up from an older modeller who was getting out of the game.
Just wondering if I can use the photos and thread to build my one, How different is your ( Nosen (not) from the original.
I have a fibreglass cowl ( which I see Bert had trouble with),
Just wondering where to begin?
Has anyone put a DLE 111 twin in this and would it fit?
I am wondering what size motor would be appropriate.
have a Super Tigre 3000, which I think may be too small, was thinking a DLE 55??
Cheers Greg
( First to see the Sun)
Old 02-01-2010, 08:32 AM
  #455
rcwarbirdbuilder
My Feedback: (104)
I don not like using the fiberglass cowl, it is to bulky, I would rather build it up. As for the Nosen kits which I have had a few of them, the plywood for most is warped and to soft along with the balsa wood, they make good templates to trace parts on to new wood. the kits need to be reinforced for larger engines, they were originaly built for a Quadra 35cc. Twins well not fit, need a large single piston engine.
My build thread uses plans along with template parts outline I drew using the Nosen kits and plans as a guide , the parts are close but do not match, anyways it is lots of fun building and flying!.
Old 02-27-2010, 05:38 PM
  #456
bert_sparrow
George here are two pix from me flying last weekend. Plane handles like a teddy Bear!
Bert
And here's a Youtube link of it flying - I really like the second landing
http://www.youtube.com/watch?v=0Tdt2QgKGGw
And this one was stupidity on my part. I know better than to try and "float" a Mustang in. Here's what happens when you forget to keep your airspeed up with flaps down.
http://www.youtube.com/watch?v=KNnK8-FrvK0
And here's the last "landing" of the day where something happened that has put my plane out of commission for a few months. Not sure what happened.
http://www.youtube.com/watch?v=j29Cd6rwnsM
ID:	1388049   Click image for larger version
ID:	1388050   Click image for larger version
Old 02-27-2010, 06:53 PM
  #457
bert_sparrow
And here's the video I should've put first. Some good passes.
Bert
http://www.youtube.com/watch?v=tIU5hK1jw64
Old 02-27-2010, 07:12 PM
  #458
rcwarbirdbuilder
My Feedback: (104)
Bert, the videos turned out great,, what a clear blue sky, and long as the plane is in one peice makes for a good day of flying!, George.
Old 03-07-2010, 08:34 PM
  #459
easyschnucki
George,
Can you tell me how you made the gun ports?
-Sven-
Old 03-07-2010, 09:47 PM
  #460
rcwarbirdbuilder
My Feedback: (104)
Sven - it was time consuming but there is no other way, I looked around but could not find any made up,,, so I took about 1/2" thick balsa and cut it into a circle, I don't remember the exact size maybe 3/4" diameter ( I would measure it but the plane was sold couple weeks ago) than the front was sanded round and curved,,, the back is sanded to the shape of the leading edge curve and glued on,, used Balsa lite filler to fill any gaps.. I drilled a 3/8" hole in the center part way and used 3/8" dowl for the barrels,, and carefully drilled 1/4" hole part way into the gun barrel,,, the hardest part was trying to get them all the same size and shape.... to finish it off I smeared epoxy with my finger over and sanded itwhen dry to get a good surface to take paint,,,, hope this helps, George.
Old 03-08-2010, 07:13 AM
  #461
kenair
My Feedback: (10)
kenair's Avatar
Enjoyed reading this thread on the Nosen P-51, I had one about 10 years ago, the Nosen flew great, though the large fuselage really wanted to weather cock over into any slight cross wind and the Robart gear had trouble handing the side load and the landing gear at time would collapse under a large side load.
cheers - ken kalynuk
www.mustang51.com
Old 03-19-2010, 04:19 PM
  #462
JWT701
Mr. Rc Warbird Builder,
I believe your name is George. I have been pouring over this thread for the lastsix months or so as I began the construction of a P-51 Nosen I received 20 plus years ago. I am going slowly as I travel quite a bit for work, but it is very enjoyable. (I could never imagine purchasing an ARF, seems to remove all the fun) Ijustreceivedthe Robart retracts with aluminum hubs you mentioned as well as numerous othertips you provided that I have followed. Suffice to saywhen I am debating which way tohandle this detail or that, I have comfortknowing this thread existsmuch like an old friend you can always depend on. I have always enjoyed a good amount of power in my planes, although I fly them scale albeit sometimes fast on a nice low pass. To this end I have decided to incorporate an APT 8.4 cubic inch inline twin with a 4 blade prop for aesthetics. Anyway, I have a long way to go, however I wanted to thank you for all of your effortand knowledge you take the time to post to the site regularly.
Thank You George,
Regards,
Jim
Old 03-19-2010, 05:44 PM
  #463
rcwarbirdbuilder
My Feedback: (104)
Jim, Thanks and good luck with what sounds like a great project. I am glad to see someone else appreciate the effort I put into the forum, George,
Old 03-23-2010, 07:26 AM
  #464
JWT701
George,
I took a few pictures of my progress. As you will note, I doubled the stringers out to W-7 and ply doubled the full rib out to W-7 as well.Based on the included stringer lenghthmy plans had stretched almost an inch per wing however the rib spacing remained consistant.I decided to build to match the plan and the doubled stringer allowed for the added length. The remaining I cut myself on a table saw. This beefed up the wing for both the landing gear and the 8.4 inline twin I am installing. I am going to created litening holes in the ribs, but as I was not sure how much litening I would need am doing so post build. Of course on the right wing I will pre-make the holes I end up creating on this wing. I decided on the Robart Aluminum 10 spoke rims and the 5.5 inch tires.
ID:	1403219   Click image for larger version
ID:	1403220   Click image for larger version
Old 03-23-2010, 10:45 AM
  #465
rcwarbirdbuilder
My Feedback: (104)
Jim looks good, once you get started the build moves along pretty good, that is the most difficult thing for most people is getting started, I tend not to over-do on lightning holes on the wings, since the wing tubes I use and wheels and retracts tend to hollow out lot of the rib area, than again it is just personal prefference, George.
Old 04-26-2010, 10:17 PM
  #466
alexzach777
My Feedback: (25)
alexzach777's Avatar
Hi George,
Which Don Smith accessories can be used on your plan for the P-51D?
Jeff
Old 04-27-2010, 07:32 AM
  #467
rcwarbirdbuilder
My Feedback: (104)
Jeff, you can use Don Smith canopy, the last one I built and posted has a DS canopy on it, it is slightly large so I trimed the edges and the final install looks good,.. The spinners I use is 6" Dave Brown,.. Fiberglass Specialties has a Nosen front cowl which fits over the entire front portion, I preffer to build up my fuselage to the spinner and make the front bottom portion which comes off, just a personal prefference it makes for a better looking construction,.. and Tony Howard who advertises on RCU has some nice exhaust stacks for the P-51 which I used,, George.
Old 04-27-2010, 02:36 PM
  #468
alexzach777
My Feedback: (25)
Appreciate both the quick reply and the advice George!
Jeff
Old 06-02-2010, 02:45 PM
  #469
rcwarbirdbuilder
My Feedback: (104)
I brought up the build thread on the P-51 for you guys who wanted to look it over again.
Old 06-02-2010, 04:21 PM
  #470
LargeScale88
LargeScale88's Avatar
Hey guys, I to have a bud nosen P-51 thats been sitting around for years. I'm in need of an engine. It has robart retracts, and flaps ect. It weighs about 23 pounds with NOengine. I was thinking a zdz 80 like Bert, and 3w 75?
Speed and good flight characteristics are almost a must.
Old 06-02-2010, 06:36 PM
  #471
bert_sparrow
dude - if I were you, I'd get a new DA-85. Pay a little extra, but you'll get quality and reliability.
Bert
Old 06-02-2010, 06:44 PM
  #472
LargeScale88
Why would you get the DA85?Everyone says the DA85 engine is for like an extra with a tuned pipe on a sport plane. Your ZDZ80 sounds awsome with that muffler!!!!
Old 06-02-2010, 06:51 PM
  #473
bert_sparrow
It WAS fine til the crank blew and cost me ANOTHER $400 with no warranty from TBM... I now have $900 in that engine, and I wish I had a DA-85.
Old 06-02-2010, 07:24 PM
  #474
LargeScale88
Well lets see here, Mines 23 pounds, A 3W 75 weighs about 4.75 pounds which makes mine about 27-28 pounds give or take a few. So a 3w 75 may work also. Are you going to purchase the DA 85 for yours sense your zdz 80 is junk? I see lots of ZDZ80 motors that run fantastic and run smooth as can be.
Old 06-02-2010, 08:32 PM
  #475
bert_sparrow
Nah, I just got it repaired, so I guess I have to keep it now...
