NEW H9 P51 Mustang 60 ARF
#677
RE: NEW H9 P51 Mustang 60 ARF
ORIGINAL: 800mZero
guys please describe this binding during rotating? ZDO you mean there is play from side to side?
Sonny
aka
jet22b
#678
CA
[link]http://www.rcgroups.com/forums/showpost.php?p=13955945&postcount=1326[/link]
My struts got sloppy after a number of flights resulting in nose overs. I found I could tighten the struts wobble by replacing the elbow pins in the anti torque linkage with a 2 mm screw whcih can be tightened down to a very slop free joint. Easy to install by sharpening the end of the screw. Also put some grease on the axle. The axles bends very easily causing the tire to rub on the strut when the landings are a little more than gentile. The axles should be hardened and not soft metal.
#679
My Feedback: (12)
MT
ORIGINAL: 172amd
My solution was to shim the aft retract mount rail to bring the wheel fwd. Yes the retract does not fit flush to the wing, but who cares.
Dave.
Dave.
Shane
#681
ORIGINAL: i7x58
I will like to ask all of you if by any chance come across the Merlin V12 engine darawings that was the P51 powerplant.I search the net and could not find the drawings.
Thank you
Adrian
Thank you
Adrian
Check out this link below to see if it help!
http://www.bluebird-electric.net/rol...lin_engine.htm
Sonny
aka
jet22b
#682
Sonny,
Thank You,
I went to this site and all over the place. I can not find the actual drawings. It is a place:
http://dynamotive.netfirms.com/merlin/
and this is 1/4 scale
a 1/5 scale:
http://www.enginehistory.org/merlin_xx.htm
I did buy a engine manual where it shows a lot of details... but I am not good @ CAD I will have to learn it first take some clases.
Thae actual engine is real complex I will like to scale down and Simplifie. with a block lenght no more than 7inch and all 10inch.
If any one interested in team up I will be more than happy.
Thank you all
Adrian
#683
FL
ORIGINAL: paracanary
Last, to take stress off of the joints I filled my tires with foam inserts to make them stiff and roll/turn better/easier.
The struts are very disappointing. I see alot of maintence there over time.
SR
#684
FL
ORIGINAL: 800mZero
Guys please describe this binding during rotating? Do you mean there is play from side to side?
I hope this helps.
SR
#686
My Feedback: (224)
Adrian
Another source might be one of the Merlins for plastic models. You'd have to develop your own plans by measuring from the model - there are some serious looking Merlins out there. I'm not sure which ones - try some of the plastic model forums.
Just a thought.
Just a thought.
#687
My Feedback: (12)
MT
Here is a link to some serious modeling/craftsmanship of a P51 and Corsair. Don't think it pertains to your needs much but makes for some very good reading. This absolutely amazing modeling. Well worth a read.
[link]http://www.craftsmanshipmuseum.com/park.htm[/link]
Shane
Shane
#689
Thanks for the additional R&D this weekend Gentlemen.
If we're going to have issues with the gear why don’t we just secure the gear and make the struts solid? Drilling through the strut while adding a screw and lock nut would work well while not being permanent. If there's no give in the gear is the plane going to be bouncing around or worse pushing the mounting blocks through the wings?
Any Robart struts that will fit?
#690
AZ
Looks great Zero!!
Are you planning to fly it with a two blade prop first? I had intended to go to a 4 blade prop, but have found (the hard way) that a large prop on this plane ends up in the ground a lot... I'm running an 18" prop, and it's very close to the ground when the plane is up on the mains. Added to the tendency this thing has to nose over, and there's not much room for error. I decided it simply wasn't worth the expense to put a four blade prop on.
#691
ORIGINAL: RodanAZ
Looks great Zero!!
Are you planning to fly it with a two blade prop first? I had intended to go to a 4 blade prop, but have found (the hard way) that a large prop on this plane ends up in the ground a lot... I'm running an 18'' prop, and it's very close to the ground when the plane is up on the mains. Added to the tendency this thing has to nose over, and there's not much room for error. I decided it simply wasn't worth the expense to put a four blade prop on.
Looks great Zero!!
#692
RI
You dont know how much this is crossing my mind eek
I am lucky enough to fly off of fields of well maintained well manicured, well watered golf green grass, I am going to try and fly it with the 4 blader if I can....
#694
FL
I'm pretty sure I can beef up the gear to my skill level and a 12.2 pound plane but I have a lot of tools at my disposal also. I'll post photos of the upgrade and try to just use a sodering ironto do the repairs. Who has the most flights on this thread? Why is this just showing up? RodanAZ stated early on that he had a failure but no other complaints of toe in. I have about 10-12 landings.
I've been looking at the Top Flite model also. I Dont think it has as many issues but it has been out a little longer.
Well I'm out for the next two weeks. No flying or building.
Have Some Fun Guys
SR
Have Some Fun Guys
SR
#695
ORIGINAL: 800mZero
I would use at least a two blade if you can. I'm so glad I hadn't yet installed my tony exhaust before my plane's maiden.
If it helps you feel better, I taxied mine all over the place and and it always rolled nicely. I actually brought mine into work just to spend a lunch hour doing some high speed taxi tests in our large empty parking lot.
Be careful Man!
#696
ORIGINAL: 800mZero
I may have to come to your field!!! Best kept grass in the world!!!
Well spent yesterday in the workshop going over my P-51 to find why the tail would not stay on the ground during ground taxi test with full up elevator. First thing I did was to move the CG from 4 5/8" to 4 7/8". To move the CG, I added 4oz of weight in the tail. Now she at the CG the manual call for. I did check and found that SR was right on the gear. Both left and right wheel was rubbing the struts. On my way to the local hobby shop to pick some wheels that will be a nice fit. I hope the weather will be go for this coming weekend so I can try her again!!!
Zero, that is one beautiful P-51. You did a very sweet job!!! I am thinking of buying one more when they are back in-stock and doing it in the 332nd Fighter Group color, ( red tail for the Tuskegee Airmen. )
Hope you have a good first flight and please post how is fly with the 4 blade prop!!!
Have a great week everyone!!!
Sonny
aka
jet22b
#697
AZ
I have around 30 flights on mine. The soldering on both struts eventually failed, and I definitely have some 'variable' toe-in from the inherent looseness of the strut/scissor design. Some good ideas have been posted on dealing with this, and I'll probably work to address the problem. I don't end up all the way on the nose all that often, and most of those have been caused by gear issues.
I think the nose over tendency comes more from the angle of the gear (wheels are too far back), and the down trim needed for level flight (the incidence thing discussed several pages back). Also, I'm running an 18" prop, which is scale, but still large for this size plane, and the gear is not correspondingly tall. When rolling on the mains, my prop is very close to the ground, and a very minor mistake will require a new prop. I have been working on this, and on one of my flap switch positions I set up a "take off" setting, which consists of only a very slight flap deflection, but takes out my elevator down trim. After take off, I switch to the flaps up position, and get my down trim back for normal flight. You have to be very careful applying takeoff power as well... if you goose it, it will go over on the nose...
And for info, I fly off a paved runway...
Zero, if I were you, I would at least fly it with a 2 blade prop until you get used to the plane. Those Zingers are pricey....
#699
FL
Worst case.
You can buy just the parts and retro fit.
http://www.robart.com/RoboStruts/440_series.aspx
SR
SR
#700
ORIGINAL: Speedracer2112
Worst case.
SR
Worst case.
SR
Sonny
aka
jet22b
