Reload this Page >
NEW H9 P51 Mustang 60 ARF
Old 04-14-2012, 03:39 AM
  #1726
chaos2984
Default RE: NEW H9 P51 Mustang 60 ARF
yea i beefed up the rear tail mount.  I put a piece of plywood down and mounted a tail wheel bracket for a .60 size plane and just had to drill the hole a little bigger.  That seems to help some but still looks a little weak.  I will have to see on the taxi test.  It was just so bad factory it wanted to fold over.  Atleast this way it doesn't want to fold over as bad.  But we will see today
Old 04-26-2012, 04:43 PM
  #1727
R/C Foolish
ok, I'm all ready to go, I think.....I'm balanced right at 4-7/8" is this correct or should it be 4-1/2"???
R/C Foolish
Old 04-29-2012, 07:08 PM
  #1728
tclaridge
tclaridge's Avatar
IMO, Put the CG at 4.5†aft of the wing leading edge and NOT 4 7/8†per the manual.
Old 04-29-2012, 07:30 PM
  #1729
R/C Foolish
I did, after rereading thru the thread, I set CG at 4-1/2...too windy to do the maiden though this weekend here in new England...I did some taxi test, lowered the position of the tail wheel to give a better angle of attack. Trying to do whatever I can to avoid nosing over, too bad Hangar 9 didn't move the gear just a little farther forward...
R/C Foolish
Old 04-30-2012, 07:04 PM
  #1730
tclaridge
tclaridge's Avatar
I raked the gear forward. I think if you fly off grass, it is a must-mod. Rake the landing gear forward by adding a 1/8†spacer or shim under the back mounting bolts of the landing gear, and remove about 1/16†material under the front mounting bolts (a Dremel works fine for this).
Also, I created 3 degrees of wing twist by putting the ailerons up by 1/16†and the flaps down by 1/8â€. This will make the plan very stable, and avoid tip stalls. It works great!!
Old 05-01-2012, 02:30 AM
  #1731
R/C Foolish
When you raked the gear forward, did you have to do any mod to the wheel opening?
R/C Foolish
Old 05-01-2012, 03:43 AM
  #1732
da Rock
ORIGINAL: R/C Foolish
...... too bad Hangar 9 didn't move the gear just a little farther forward...
R/C Foolish
Yes to that.
I usually angle the gear forward (as described by tclaridge) and it helps. Only problem is the wheel will be slightly canted in the wheelwell.
Old 05-02-2012, 04:57 PM
  #1733
tclaridge
tclaridge's Avatar
There is a slight angle to the gear doors when retracted, but it is not bad. They clear the wheel well without any mod.
Old 05-02-2012, 05:01 PM
  #1734
R/C Foolish
Ok, I canted the gear and changed the CG to 4-1/2...I'm ready for the maiden, hopefully this Sat.
R/C Foolish
Old 05-05-2012, 02:13 PM
  #1735
R/C Foolish
Well it was a very short maiden flight. Started to roll down runway, building speed and not pulling on elevator, plane broke the ground, started to climb applied a little elevator and she just did a slow roll to the left and went nose in. I believe it tip stalled, I tried to go full right aileron, nothiong. She is a total loss. Motor and gear ok though.....maybe I will try the Top Flight ARF.....
R/C Foolish
Old 05-05-2012, 04:25 PM
  #1736
jet22b
jet22b's Avatar
R/C Foolish,
Sorry to hear about your maiden flight!! That was the same way my Blue Nose went in. As for the Top Flite P-51 ARF, you are going to love it I have one and I never look back at the Blue Nose. In fact I just came in from flying my Top Flite P-51 with a Thunder Tiger 1.30FS in the nose. I had a Magnum 1.20FS in her, but the engine gave out, so I pickup the Thunder Tiger from Tower Hobbies. I like this new setup!! Flies like a dream!!
Try the Top Flite ARF and see what you think!!
Again, sorry about your maiden flight!!!
Sonny
aka
jet22b
Old 05-05-2012, 06:56 PM
  #1737
ALWAYSPDG
How much ground speed do you obtain before rotating the nose to lift off?
Is it possible you didn't have enough airspeed and as you climbed it tip stalled and rolled over?
Sorry to hear about your maiden flight, that bites!
Mike
Old 05-06-2012, 06:02 PM
  #1738
chaos2984
sorry to hear about ur nose in.  But i too lost mine on the maiden flight as well.  But mine pancaked in.  Its repairable.  The wings need rebuilt a little and a new motor mount fire wall.   I had the club pro fly it first to get it up and trimmed out.  It was flying fine and was flying good.  But he was coming around at 1/2 throttle and it just quit.  He tried to bring it in as best he could but bad deal and it pushed the gear threw the wings.  The gear mounts are very strong just not the rest of the rib.  Im rebuilding it stronger.  And going for another test flight again after it is rebuilt.  Im getting close.  I'm going to get with a building guy and have him help me put everything back together after i have all the pieces  cut.
But overall he said the plane was flying well and smooth
Old 05-07-2012, 07:00 PM
  #1739
tclaridge
tclaridge's Avatar
R/C Foolish, I wish it went better for you. Sorry. I would be interested to know if it was a full throttle TO, and if so, what motor? Also, did you try the wing twist trick? Just trying to figure out why this bird is having so many problems.
I hope your next P-51 is a great success.
Old 06-06-2012, 05:37 AM
  #1740
paladin
My Feedback: (9)
anyone know when the next batch arives?
Joe
Old 07-04-2012, 04:32 PM
  #1741
Jason Lewis
4 Month build. Finally finnished! V-2, 10 lb 4 oz, Saito 125A, Keleo functional Exhaust, Retract tail wheel, Sequenced Main Gear doors- tail wheel doors, functional radiator exhaust, Highly Detailed Full cockpit. Whew... it's been fun!
ID:	1778674   Click image for larger version
Old 07-04-2012, 04:35 PM
  #1742
Jason Lewis
Gear up, with doors closed, radiator exhaust open
ID:	1778676   Click image for larger version
Old 07-04-2012, 04:37 PM
  #1743
Jason Lewis
Tail wheel door mechanism, main door mech
ID:	1778678   Click image for larger version
Old 07-04-2012, 04:40 PM
  #1744
Jason Lewis
Engine compartment, battery was eventually moved aft to ballance
ID:	1778680   Click image for larger version
Old 07-04-2012, 04:43 PM
  #1745
Jason Lewis
Cockpit
ID:	1778682   Click image for larger version
Old 07-04-2012, 04:47 PM
  #1746
Jason Lewis
The Real plane.. Fantasy of flight. Orlando FL
ID:	1778684   Click image for larger version
Old 07-04-2012, 05:30 PM
  #1747
jet22b
jet22b's Avatar
Jason Lewis,
You did a great job on your P-51!!! Please come back with your flight report. I have the Keleo functional Exhaust on my H9 Spitfire and just love it!! Yes your plane get more oil on it, but, that's the life of a warbird!!!
Sonny
aka
jet22b
Old 07-04-2012, 05:40 PM
  #1748
Jason Lewis
Hatch and radio compartment
ID:	1778713   Click image for larger version
ID:	1778714   Click image for larger version
Old 07-04-2012, 05:47 PM
  #1749
Jason Lewis
My cockpit detail photos are on page 68 Post # 1682-1688
ID:	1778716   Click image for larger version
ID:	1778717   Click image for larger version
Old 07-05-2012, 08:52 AM
  #1750
tclaridge
tclaridge's Avatar
Jason, awesome job. Thx for sharing.
