Ziroli 124" F4U-5N Corsair Build
#877
RE: Ziroli 124
ORIGINAL: TomCrump
I would not use EZ connectors on any surface of a model of this size.
#878
My Feedback: (221)
RE: Ziroli 124
I use them on my giant scale and have for years with never a failure. I use the heavy duty ones and never the plastic retainers. The metal retainers need cut off to take them apart, they hold that good. Even in crashes, I have never had a pin break on the 4-40 size ones. I don't get why they are getting such a trashing here.
#879
WI
RE: Ziroli 124
hey barry. looking good. but still not like a p-40. just kiddin. going flying sat. afternoon. weather suposed to be good. ya coming out? time to blow the dust off them barfs. let me know. keep up the good work. want to see them retracts.
#880
RE: Ziroli 124
ORIGINAL: ram3500-RCU
Some people only read part of the posts and don't know what is really going to be used for what. I can't blame them but I do wish they would comprehend what I'm writing before they give their opinions. Andy I am going to Toledo for the weekend. Ya wanna come along? I'm leaving Sat morning around 9 and coming back Sunday after the shows over. I wanted to leave Fri morning but business has me stuck here for move ins.
#883
My Feedback: (43)
RE: Ziroli 124
That 4-40 rod will flex under a load on something that big. You are also depeding on the strength of a non-hardened steel rod that has been bent 90 degrees futher weakening its internal strength. All of the stress is being handled in that 90 degree bend.
If you were using me as an observer to get your overweight certification, I would not sign off with those pushrods. There should be ball link on either end that is bolted to both the servo arm and the control surface horn. If you insist on using the 4-40 rod, it should be sheathed in a properly sized carbon rod to eliminate the flex along with threaded solder connectors and ball links.
#884
My Feedback: (81)
RE: Ziroli 124
Jeff is correct. It is rare I use 4-40 on the big stuff. Typically cut my own threads on 1/8 welding rod (steel or stainless). But, if I do use 4-40, which I did on the 12 foot spit flaps and ailerons, I sheeth in in carbon tube/rod and used DuBro 4-40 swivel balls.
The thing to keep in mind is that the air pressure will be working in compression against that flap rod, so it will bend. I'd feel better if is was used in a tension application.
Me, I always try to rig my flaps so that when deployed the rod is in tension.
Jeff
Jeff
#885
RE: Ziroli 124
I am heeding your advise. I will use a carbon fiber pushrod with a carbon fiber sheath. I will use the carbon fiber tips so I can use a 4-40 ball link on each end. Now I will need to know where to get the CF rods, sheaths, and tips. How about a link please! Also do the tips get epoxied onto the rods or do I need to thread the ends that aren't already threaded where they attach to the servo arm?
Gary,
I don't know now if I will be able to make it to Toledo. I need my friend to come along to share expenses. He said he would let me know today after he gets off work.[&o] I was really looking forward to meeting you and seeing Zombie in person.
Gary,
#886
RE: Ziroli 124
OK, I went back to the last page and checked out the link provided for carbon fiber tubes and titanium tips. I included a picture. Now let me get this straight. Your saying carbon fiber tubes and titanium tips attached with JB weld is the way to go? Or are there just solid carbond fiber pushrods that I can JB weld the titanium tips onto? Help me out here. I just want everybody to know I thank you for helping me prevent crashing my baby with your helpful opinions. I do want the flaps to be very strong. I just never used carbon fiber for anything before. I guess I'm to old school oriented.
#887
My Feedback: (8)
RE: Ziroli 124
We posted at the same time.
Barry, Here is the link again.
http://www.abellhobby.com/category-s/342.htm
Here is the Big bird kit. Comes with 16 threaded tips and a two 32" long carbon fiber rods.
http://www.abellhobby.com/Crashis-Cl.../cccfprkbd.htm
these are the stainless couplers. they are a lot cheaper than titanium.
#888
RE: Ziroli 124
Thanks Kelly,
I am going to get the next kit up which is the same except it has titanium tips. I think stainless steel is to soft don't you agree?
#889
My Feedback: (43)
RE: Ziroli 124
Central Hobbies sells CF pushrod kits with 6-32 fittings on the end. They also sell MK ball links that are for 3mm/6-32 rods. You can also get small heim joints that will work with 6-32.
http://www.centralhobbies.com/contro...e/pushrod.html
look through the larger RC Rock Crawler's hardware. They have lots of heavy duty parts for suspension links and tierods.
#891
RE: Ziroli 124
ORIGINAL: JeffH
Jeff are those still tubes or solid carbon fiber rods? Now I'm getting confused![X(] On AbelRC they sell the tubes for less and they have tips that go over the tube to prevent lateral splintering. The pictures on your link show the tip sliding into the tube which doesn't prevent the lateral splintering. Are these the same? Cuz if they are AbelRC is cheaper for theirs.
#892
RE: Ziroli 124
I vote for the glass. You put your plans under it and then use thin CA to hold parts down to it. Afterwards a little scrape with a razor blade and it all comes off.
#894
RE: Ziroli 124
ORIGINAL: raptureboy
Thanks Jeff Q.
#895
RE: Ziroli 124
My retracts were delivered yesterday but I was to busy to post pictures of them. Here they are setting on the original ribs. I will be removing the original #5 & #6 ribs and replacing them 4 1/4" apart perpindicular to the building surface. I already removed the ribs on the right side and just have the left to go before I use my templates made of balsa to cut the 1/4" aircraft ply ribs that will replace the 1/8" ribs. Then I will use maple or poplar to make the rails for them to be bolted to. They have a 1" diameter strut and 5/16" axle. They measure 11 5/8" from the pivot point to the center of the axle. The wheels will just fit. They are just under 8" in diameter.
#897
RE: Ziroli 124
Gary,
Darrell was supposed to ship me air line, brass T's, and quick connects. Is there anyway you can get these from him tomorrow for me and ship them? Just let me know how much they are with shipping and I'll send you a money order. I need about 20 feet of air line, 15 brass T's and 8 quick connects. If I wait for Darrell it could be a long time before I get them because he is so busy. I sure wish he hadn't forgot to ship them. If you tell him they are for me he will probably just give them to you and invoice me! Then all you will have to do is pay the shipping which shouldn't be much. Sorry I couldn't make it but we had a medical emergency in the family. My mother in law was rushed to the hospital to prevent a serious stroke. Only to find out she has a terminal disease.[&o] I cut out my 1/4" aircraft ply for my retract ribs and used my newest addition to my shop. Now I don't know how I got by without it. Now I can cut about 1/16" to 3/32" outside the traced line on the parts and boy does it ever take it away fast and leaves a perfectly square or angled edge everytime. I Love it.
Thank You my Friend,
#898
My Feedback: (221)
RE: Ziroli 124
ORIGINAL: NCIS
Gary,
Darrell was supposed to ship me air line, brass T's, and quick connects. Is there anyway you can get these from him tomorrow for me and ship them? Just let me know how much they are with shipping and I'll send you a money order. I need about 20 feet of air line, 15 brass T's and 8 quick connects. If I wait for Darrell it could be a long time before I get them because he is so busy. I sure wish he hadn't forgot to ship them. If you tell him they are for me he will probably just give them to you and invoice me! Then all you will have to do is pay the shipping which shouldn't be much. Sorry I couldn't make it but we had a medical emergency in the family. My mother in law was rushed to the hospital to prevent a serious stroke. Only to find out she has a terminal disease.[&o] I cut out my 1/4'' aircraft ply for my retract ribs and used my newest addition to my shop. Now I don't know how I got by without it. Now I can cut about 1/16'' to 3/32'' outside the traced line on the parts and boy does it ever take it away fast and leaves a perfectly square or angled edge everytime. I Love it.
Gary,
Question, does it have to be Sierra? I think all these items are available from several suppliers at the show.
Sorry to here about your family problems. Hope she can be made comfortable. Very sad news indeed.
I'll post tomorrow evening and let you know how I made out.
#899
RE: Ziroli 124
Gary,
The show is over now but anybody's quality stuff wouild have been fine! Sorry for the slow reply but things are really crazy at my house right now. My mother in law Sue lives with us so we have been giving her constant care. I am beat to the nub and so aren't my wife Dena and teenagers, Skylar 17 yoa ,and Quinn 16 yoa. I am happy to say that the kids are really helping us out. Without them we would lose this battle.
Thank you Gary,
Thank you Gary,
#900
My Feedback: (221)
RE: Ziroli 124
ORIGINAL: NCIS
Gary,
Thank you Gary,
Gary,
Thank you Gary,
I got your air line (20') and disconnects (4 pair) from CJ. He didn't have the Ts on hand. Darrel did, but they were $1 more each. Plus, Bruce from CJ pointed out that he made some with 1 in and 4 out. I thought this might eliminate some connections and make things easier. He will ship them right out to you if you want. Just tell him your the guy Gary Prince got the stuff for a the show.
The stuff I got came to $35.
Hang in there,
Gary
