Will a Zenoah GT 80 fit inside a Ziroli Corsair?
My Feedback: (28)
RE: Will a Zenoah GT 80 fit inside a Ziroli Corsair?
I think the GT80 has been done, I know at Topgun there was one with the BME110 installed, have a look here this link you should find it here. http://www.rcuniverse.com/magazine/a...rticle_id=1125 Brian O'meara is the owner.
I have the same kit and was planing on installing the DL100 with a 2-1/2in prop adaptor.
Check6, I just checked nick's web page and pulled up the corsair and it does list the GT 80 as one of the engines of choice to power the corsair so i'm assuming that it does fit. The only other thing you could do is order the shorter plugs for it to make it fit better without any interferance on the sides of the cowl.
My Feedback: (65)
Here is what someone did over at RC Scalebuilder: http://www.rcscalebuilder.com/forum/...?TID=9501&PN=6
CH has the short plugs and plug caps...
My Feedback: (72)
It will fit but RAMFlyer is right you need the CH short ignition boots to make it fit. You may also need to change the plugs. I also know it must be completely centered in the cowl.
http://www.rcuniverse.com/forum/m_45.../tm.htm#453205
Peter
Peter
