Ripmax Tiger Moth
Ripmax Tiger Moth
Hi,
I got the Tiger Moth second hand today but no manual. I want to check the COG, can anybody give me a suggestion where it should be. I am not sure with biplanes.
Progo
Progo
RE: Ripmax Tiger Moth
G'day mate ,
I have 3 'moths from a littles GWS foam one up to a 76" Green Models and I balance them just in front of the rear of the "fuel tank" mounted on the cabane struts. and as always nose heavy is better than tail!!
good luck
spud
good luck
spud
I have one of those too, I think, and have the manual somewhere - I'll try to find it to give you a definite answer.
You can see mine in the attached photos - both in the original covering and after recovering.
Richard
Richard
Oh,see an [link=http://www.rcuniverse.com/product_guide/kitexpertreview.cfm?editorial_id=232&kit_id=2645]online review here e[/link]
Richard
Richard
Can't find the manual but I added a servo screw under the upper wing at the CG when I recovered it so I measured that. It is 125mm from the front of the upper wing (perhaps 100 from the trailing edge).
HTH
Richard
p.s. OldFart1, Ripmax is a UK company and I think their products are only available in the UK.
HTH
Richard
Thanks Richard for the information this will help a lot.
@ Old Fart1
Ripmax is a wholesale distributer, you need to find a dealer who will ship the stuff to you. Try Moor Models (http://www.moormodels.co.uk/) or Sussex Models (http://www.sussex-model-centre.co.uk/) they may do it but I am not sure.
Ciao Progo
@ Old Fart1
Ciao Progo
You are welcome, Progo. When I said "perhaps 100 from the trailing edge" I meant "perhaps 10mm from the trailing edge"! Sorry!
Oldfart1, I concur on Moor Models - I've used them many times - even when I lived in South Africa - and never had a problem.
Richard
Richard
Moor doesn't list the Ripmax Tiger Moth - at least I didn't see it under the Ripmax section
I think we need to have our next Airport Conference in the UK - I need "stuff"
Oldfart1, it appears Ripmax don't do this Tiggie any more so I guess you will battle to find one unfortunately.
But yes, there is some nice 'stuff' available over here!
Richard
Richard
