Reload this Page >
ESM LA-7 From VQ Warbirds
Old 11-02-2016, 12:29 PM
  #1001
Joespeeder
Thanks Scale,
I use mainly Hobbico Life batteries and I have some from Cheetah due to their form factors. Electrodynamics has a charge cord that allows balance charging the Life batteries into a Ernst (servo style) end and they will custom make the harness end that goes in your plane.
The harness end just plugs into the Hobbico balance tap end of the battery and gets hidden somewhere on the fuse. Once done it's a simple Ernst (servo style) connector that you can plug in and charge at the field just like the NiMh of old.
I set my port on the fuse so that the ground wire is closest to the ground if vertical or closest to the tail if it's aligned front to back in the fuse. That way I align the ground wire as either the most rearward or the most downward wire as I'm pluging in the Ernst plug and I always know which way to plug it in. Another way to think of it is Positive forward or Positive up.....
The charger cord is a stock item. The Harness for the fuse you need to call Electrodynamics directly and it comes about 2 days later.
Joe
Name:	Electro Plugs.png
ID:	2188629   Click image for larger version
Old 11-03-2016, 03:04 AM
  #1002
Sheraaz
Sheraaz's Avatar
hi guys
my 80" LA-7 nearing completion after about a month's work. I've heard of the weld joint on the Elev control linkage coming loose on the 30cc esm kits. Just wandering if anybody had any issues with the Elev control link on the 80" kits?
thx in advance
Old 11-03-2016, 07:40 AM
  #1003
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Originally Posted by Joespeeder
Thanks Scale,
Joe
A lot of ways to skin a cat right?,, LOL, I guesg they make an adapter cable for everything now,
I forgot to mention, I use the Cellpro Multi4 charger, so I don't need the power leads connected,, it does all the charging through the balance tab. Also if you plug it in backwards,,the charger just doesn't start automatically up like it does when you plug it in right,, so no need really to remember orientation.
Good luck
P.s.
Another small issue I've had with the Ernst charge receptacle is the plug coming loose when you push the charge lead in, if you look back at my photo you'll see a short extension between the battery and the receptacle,, I glue that in so it doesn't fall out into the fuse, I had that happen a few times,, very frustrating
Old 01-16-2017, 05:06 AM
  #1004
Propellars
Propellars's Avatar
Default fg60r3
Hi guys
Do you think a Saito fg60r3 (2,1 kg / 4,7 lbs) will be too heavy for the LA7?? I sure like the sound of those radial, and I believe that fg33r3 might be underpowered..
I have read this whole thread now, and watched tons of videos. Do you think theese nasty ground-looping and landing habits will worsen with this engine?
Old 01-16-2017, 09:41 AM
  #1005
radfordc
My Feedback: (14)
radfordc's Avatar
The FG60 should be fine.
Old 01-17-2017, 03:42 AM
  #1006
Sheraaz
Sheraaz's Avatar
Mine is flight ready [maiden not done yet] with the FG60. No added weight needed balanced just right. more pics/ video here: www.facebook.com/planecrazyrc
Old 01-18-2017, 03:22 AM
  #1007
Propellars
Propellars's Avatar
How is the slow flying ability for the LA-7 really? Are you only flying max speed all the time, as I see in all the videos, or do you also dare to make slow passes with flaps?
Old 01-18-2017, 03:44 AM
  #1008
Sheraaz
Sheraaz's Avatar
Default hahahaha
funny guy..yes ofcourse I fly them slow too but you missed the part "maiden not done yet" so I have no idea how she flies other than what i've found on youtube - it will be be fine
Old 01-18-2017, 07:52 AM
  #1009
radfordc
My Feedback: (14)
radfordc's Avatar
It flys great....fast or slow. Just be careful not to land too slowly or takeoff before flying speed is achieved. Land on the main wheels and then slow down. On takeoff make sure the tail wheel is off the ground before you try to takeoff.
Old 01-19-2017, 07:54 AM
  #1010
Propellars
Propellars's Avatar
Thanks radfordc
Old 01-19-2017, 08:19 AM
  #1011
radfordc
My Feedback: (14)
radfordc's Avatar
Here is what happens if you try to takeoff before getting enough speed.
ID:	2197315   Click image for larger version
Old 01-19-2017, 01:24 PM
  #1012
n8622t
My Feedback: (8)
RIGHT RUDDER!!!!!!!!!!!
Old 01-19-2017, 02:48 PM
  #1013
radfordc
My Feedback: (14)
radfordc's Avatar
The right rudder was just coming in....but too late. Out of airspeed, altitude, and ideas.
Old 07-06-2017, 07:06 AM
  #1014
Joespeeder
Hey Guys,
Looks like 2 of the La-5/7's from this thread may be flying together soon ! A good friend told me at the field last night he might be buying Scales LA-7?? He described the plane and I think that's the one he's looking at buying. No matter what, I think I'll have a La-7 to fly with this year. I had an intense family health winter and lost months of modeling due to having to be a caregiver. Things are good now and I plan to get the La-5 out by the end of next week. Hopefully John can get his flight ready quickly so we can fly together. He flys full scale Hawker Jets for a living and is a great RC wingman.
I have Nitro, Methanol, and oil to mix my own fuel for the Laser 300v and will be running it on a 10% and 10% just like the Large Super Tigers.
I have a BH Storch that I'm finishing up with a Laser 300v that is set up for sailplane tug duty. That was supposed to be my fall build last year. Quick and simple. Alas, life changed those plans. The Storch is almost done and then the La-5 will fly again !!
Here's a shot of the crew installed in the Storch. I found a retired HE-111 pilot and his Sgt who owned Germany's largest toy manufacturer before the war. They fit the project perfectly but I have my doubts about them actually spotting anything !!!
Joe
Old 07-22-2017, 10:13 AM
  #1015
piwie
Hello
I'am using in my ESM LA 7 retracts from Sierra.
I fly the LA 7 with an DLE55 by weight from 12kg.
The retracts a very soft, and I will change the spring in the struts.
And now I have the Problem , who knows where I can opening the Sierra struts ?
Frank
Old 02-14-2021, 06:42 AM
  #1016
Prekin
My Feedback: (19)
Prekin's Avatar
La-5FN is back on desk. There were some repairs needed after take-off crash. New plate for fuel tank designed.
ID:	2269354   Click image for larger version
ID:	2269355   Click image for larger version
ID:	2269356   Click image for larger version
ID:	2269357   Click image for larger version
ID:	2269358   Click image for larger version
ID:	2269359   Click image for larger version
ID:	2269360   Click image for larger version
scale only 4 me (02-14-2021)
Old 03-12-2021, 08:27 AM
  #1017
Prekin
My Feedback: (19)
Prekin's Avatar
New pilot for my La-5FN .
Old 03-12-2021, 12:34 PM
  #1018
acemcduck
My Feedback: (17)
acemcduck's Avatar
Thumbs up
Wow.....................very nice.
Old 04-18-2021, 06:25 AM
  #1019
Prekin
My Feedback: (19)
Prekin's Avatar
I placed pilot into cockpit. He looks a little bigger that he should be, but problem is the cockpit. Pilotīs seat should be lower.
Old 10-10-2023, 09:31 AM
  #1020
sailr
My Feedback: (25)
What the heck? All are Rustoleum but the clear isn't compatible with the camo? I'd piss a fit to Rustoleum. Unless it specifically says on the label to not mix them, I'd P and moan to Rustoleum!
