Reload this Page >
Knowledge Quiz for Warbird wiz
Old 12-11-2010, 02:08 PM
  #3751
tenacious101010
My Feedback: (97)
Default RE: Knowledge Quiz for Warbird wiz
Nope, I would be quite surprised if anyone got this one. The only reason I know it is because I saw the name cast into the block.
Old 12-11-2010, 02:09 PM
  #3752
glasscock
Volks Wagon.
Old 12-11-2010, 02:11 PM
  #3753
tenacious101010
My Feedback: (97)
LOL, nope, not that I am aware of, I will give a hint, it is and was an American owned company.
Old 12-11-2010, 02:15 PM
  #3754
glasscock
Okay, it was Ford.
In June 1940, Henry Ford had offered to manufacture 1,000 aircraft a day if the Government would let him do it his way, and during a discussion with Secretary of the Treasury Henry Morgenthau Jr. regarding what the Ford company might produce, Ford's son Edsel tentatively agreed to make 6,000 Rolls-Royce liquid-cooled engines for Great Britain and 3,000 for the U.S.[
Old 12-11-2010, 02:17 PM
  #3755
tenacious101010
My Feedback: (97)
Nope, and not dodge or chrysler.
Old 12-11-2010, 02:23 PM
  #3756
masteromodels
Maybe Studabaker ?
Old 12-11-2010, 02:27 PM
  #3757
masteromodels
last try Hudson ?
Old 12-11-2010, 02:28 PM
  #3758
tenacious101010
My Feedback: (97)
Good guess, but no, Studebaker did build aircraft engines, Kermit weeks has a Studebaker engine on one of his aircraft at Fantasy of Flight here in Florida, but thats a question for another time. I reviewed my pictures, actually there were two companies that made blocks for Packard Merlins.
Heres a pic of my Studebaker
Old 12-11-2010, 02:32 PM
  #3759
tenacious101010
My Feedback: (97)
Not Hudson, neither of the two companies had any aviation experience at all that I am aware of. I am headeed out to a work Christmas party, I will respond when I get home. I didnt mean to disrup the flow of the thread. I believe its Glasscocks turn, but I have so many when its my turn again. I will post the answers and the pictures of the names cast into the blocks tomorrow
Denny.
Old 12-11-2010, 02:43 PM
  #3760
tenacious101010
My Feedback: (97)
Since its Glasscocks turn, I will end my turn with these two images. These are from two earlier Merlins I restored.
Denny
ID:	1532954   Click image for larger version
Old 12-11-2010, 02:44 PM
  #3761
uncljoe
My Feedback: (8)
uncljoe's Avatar
Must agree with you the SeaMaster was an AWESOME sleek machine along the likes of the Hawker Hunters . But then again Beauty is in the Eyes of the Beholder.
engine blocks guess Singer Machine & USSteel.
SF
Joe
Old 12-11-2010, 03:25 PM
  #3762
glasscock
Name the airplane and something special about the tail cone...
As far as the company that cast the engine block...how about White Sewing Machine?
Old 12-11-2010, 07:31 PM
  #3763
tenacious101010
My Feedback: (97)
I just discovered this thread, after reading several of them I had a rough idea, at least some semi-intellinent guesses. This one I absolutely have no idea.
The two companies tha turned out the Packard blocks were Maytag and Buick. There could be more, but these are the only ones I know for sure.
Denny
Old 12-12-2010, 05:53 AM
  #3764
glasscock
Here's a little more info on the above aircraft in question:
A fundamental concept of this aircraft was that it had NO TAIL (to save weight and drag) and NO CONTROL SURFACES anywhere - the engine cluster was gimballed in three dimensions to act as rudder, ailerons and elevators.
Old 12-12-2010, 01:07 PM
  #3765
glasscock
Some more info on the aircraft in question...
What if one the engine fails?
This is one of the main objections levelled at the design, both at the time and by modern aerodynamicists. In the swept configuration, the engines are so close to the centerline that an engine-out is not a problem. In the unswept configuration, it is potentially a big deal, but the designer designed an automatic (mechanical) sensor which looked for equal thrust from both wings. If imbalance was detected, the engines on the working side were set to "toe-in" which reduced the thrust on that side and restored the thrust line to within a manageable region. This would have worked within half a second, before the pilot even spotted the engine-out.
Old 12-12-2010, 06:12 PM
  #3766
Ernie P.
ORIGINAL: glasscock
I'm lost. Was this possibly a "paper only research exercise"? Or was it actually built? Thanks; Ernie P.
Old 12-13-2010, 03:51 AM
  #3767
glasscock
More info:
The designed aircraft in question never flew. It was to have a span of 75 feet with wings extended and 31 feet when fully swept; it was to be powered by four Bristol afterburning turbojets, giving it a top speed in excess of Mach 2. The aicraft was seen as the basis for a one or two seat combat aircraft, most prominently an interceptor armed with air-to-air missiles.
The late 1950s were a dismal time for the British aviation industry, with many promising development programs shut down. The aircraft in question was never built; there were discussions with the Americans on further consideration of the design, with the US National Aeronautics & Space Administration (NASA) performing advanced studies on the concept. By mid-1959, NASA had concluded that the aircraft itself was aerodynamically dubious but the variable geometry concept was seen as very promising, with further work in the USA leading to the world's first operational variable geometry aircraft, the General Dynamics F-111.
Old 12-13-2010, 07:04 AM
  #3768
glasscock
More info:
Designer live to the age of 92. Sir Barnes Neville Wallis.
This aircraft flew in model form in the mid-fifties. Subsonic tests were made with a model of 30 foot maximum span powered by two small rockets. A supersonic model, 6 feet long attained speeds of up to Mach 2.5.
Old 12-13-2010, 10:13 AM
  #3769
Experten109/40
My Feedback: (-1)
Experten109/40's Avatar
so it wasn't actually the plane that was flying. it was the rockets that were flying the plane.
ie: with a big enough propellor & engine a brick can fly too.
anyways, thats the Swallow.
Old 12-13-2010, 10:45 AM
  #3770
glasscock
Good job, Mr Spitfire is up! (An anonymous PM'er had the right answer also ).
So I do not tie up anymore time, I'll let the tailcone answer slide, but research the bouncing bomb. It was a nuclear bomb.
Sir Barnes Wallis genius brought totally new ideas to aviation. Here's a good book for anyone interested...
http://www.amazon.co.uk/Bouncing-Bom...0313149&sr=8-1
DG
Old 12-13-2010, 10:55 AM
  #3771
glasscock
The Vickers Swallow.
Old 12-13-2010, 11:00 AM
  #3772
Experten109/40
My Feedback: (-1)
thanks. good question.
anyways put on the old P-40 thinking caps. will come up with a question in a bit.
that cannot be googled or wiki'ed.
Old 12-13-2010, 03:52 PM
  #3773
Ernie P.
ORIGINAL: glasscock
DG
A nuclear bomb? Now that I never heard! With a heavy bomb mounted that far in the rear of the aircraft, it seems you would have problems. Most (if not all) bomber aircraft have the bomb load pretty much centered up on the wings, so as not to upset the CG when the bombs are dropped. Remember how many problems were caused when Hitler wanted bombs mounted on the Me 262? They couldn't put the bombs on the wings or centrally mounted on the fuselage because of the landing gear. Mounting them at the forward part of the nose gave them fits.
Of course, I guess if the Swallow underwent a big CG shift, the engines could just gimbal to compensate? Hmmm..... Maybe he had more there than I thought. Thanks; Ernie P.
Old 12-13-2010, 04:05 PM
  #3774
glasscock
Nuclear bomb? This is one artifact that touches on this...
"This is a completely separate programme but was proposed to the RAF as a V bomber replacement (the tail cone was an aft firing nuclear weapon to allow weapons release while moving away from the target) and also as a mach 3 cruising SST."
In reality, who knows?
Old 12-13-2010, 04:25 PM
  #3775
Experten109/40
My Feedback: (-1)
ok, most if not all people think the the P-40 was never equipt with rockets. so if thats the case,
whats this P-40 carrying under her wings? I need its common name and its nickname.
