Knowledge Quiz for Warbird wiz
#5701
RE: Knowledge Quiz for Warbird wiz
Some clues too...
1) the pictures
2) only two were built. Unreliable engines hampered development, and then other good designs became readily available
3) it was designed as a heavily armed escort fighter and ground attack aircraft
1) the pictures
#5702
4) like earlier and better known designs from the same design bureau, it had a wooden monocoque fuselage and used metal structures in the wings
5) the wing included automatic slats
#5706
ORIGINAL: makmov
Polikarpov ITP M-2 Prototype.
(ITP for Istrebitel Tyazholiy Pushechniy; Russian: ΠΡΡΡΠ΅Π±ΠΈΡΠ΅Π»Ρ Π’ΡΠΆΠ΅Π»ΡΠΉ ΠΡΡΠ΅ΡΠ½ΡΠΉ; Heavy Cannon Fighter)
http://en.wikipedia.org/wiki/Polikarpov_ITP
Your turn, makmov.
#5708
CO
1. In WWII they made 1 at the cost for nearly $5,000,000.00 which ended in failure and wascanceled 1944.
2. It used inverted V-12s
But it sure looked cool.
#5709
ORIGINAL: makmov
1. In WWII they made 1 at the cost for nearly $5,000,000.00 which ended in failure and was canceled 1944.
Douglas XB-19?
#5710
Looks like the XB-19 had radial engines, not V, and the timing is not quite right.
Same goes for Vought's XF5U, Republic XF-12 Rainbow, and Hughes D-2 and XF-11, I think.
#5711
CO
ORIGINAL: MajorTomski
Douglas XB-19?
ORIGINAL: makmov
Douglas XB-19?
#5712
McDonnell XP-67 "Bat" looked cool, used inverted vees, was canceled in 1944, and was a P. Don't know how much money went into it...
#5713
CO
ORIGINAL: perttime
ding,ding,ding You got it brother. It was 4.8 million = 61.8 million in todays dollars, and it was a failure, it didn't preform very well, for a number of reasons, notwithstanding, the underpowered, inverted Continental engines, and ending up catching fire and burning to the ground.
#5714
http://en.wikipedia.org/wiki/McDonnell_XP-67
If anyone has something handy to post, please go ahead. I'll look for something if nothing happens for a while.
Meanwhile, a pic of the Bat:
#5715
HI
I have an interesting one.
1. This is an airborne weapon
2. It was used in four missions all on the same day and, as far as I am aware, never again.
#5717
HI
The clues point to the bouncing bomb, as will some of the others, but it is something very different...
3. It featured in a very well known war movie.
#5718
HI
4. Its effectiveness was augmented with parallel missions by special forces
#5719
HI
Need to do better homework....
2. It was used in four missions all on the same day and, as far as I am aware, never again.[b][i]
#5720
HI
2. Its most famous use was in four missions all on the same day.
5. It never killed anybody but confused the heck out of them.
6. It has been used by the Germans, British and most recently Americans (as recently as the Gulf War).
#5721
HI
Time for another clue...
7. In some later operations, ice was sometimes substituted for the main body of the weapon.
#5722
HI
Last one for the day and this should narrow things down a bit.....
4. Its effectiveness was augmented with parallel missions by special forces.
8. On the same day, in a parallel operation RAF heavy bombers in cooperation with Royal Navy small ships flew sorties with a similar objective, to confuse the Germans.
#5723
Sounds like a countermeasure
"Chaff" (strips of aluminum foil or similar material) was first used in 1943 to confuse German radars to protect bombers during the devastating Hamburg bombings.
For the Normandy landing in 1944, it was used to fool Germans into holding their forces in the wrong place, in operations Glimmer and Taxable, by creating the impression of a large fleet. Low flying bombers were dropping chaff and small ships added to the radar clutter.
The Brits codenamed it "Window" at the time. Wikipedia also mentions "Rope" - extended-length Window suspended from small parachute and dropped by aircraft of 218 and 617 Squadrons intended to deceive German Seetakt coastal radars - for Operation Glimmer and Taxable.
#5725
ORIGINAL: SimonCraig1
