Reload this Page >
Knowledge Quiz for Warbird wiz
Old 01-18-2018, 05:42 PM
  #15276
FlyerInOKC
FlyerInOKC's Avatar
Thumbs up
Originally Posted by Wagon1
Douglas A1 "Spad"?
Give that boy a burnt cookie!
Douglas A-1 Skyraider
From Wikipedia, the free encyclopedia
A-1 (AD) Skyraider
U.S. Navy A-1H Skyraider from Attack Squadron VA-152 over Vietnam in 1966.
Role Attack aircraft
National origin United States
Manufacturer Douglas Aircraft Company
First flight 18 March 1945
Introduction 1946
Retired 1985 Gabonese Air Force[1]
Status Retired
Primary users United States Navy
United States Air Force
Royal Navy
Republic of Vietnam Air Force
Produced 1945–1957
Number built 3,180
Developed into Douglas A2D Skyshark
The Douglas A-1 Skyraider (formerly AD) is an American single-seat attack aircraft that saw service between the late 1940s and early 1980s. The Skyraider had a remarkably long and successful career; it became a piston-powered, propeller-driven anachronism in the jet age, and was nicknamed "Spad", after the French World War I fighter.[2]
It was operated by the United States Navy (USN), the United States Marine Corps (USMC), and the United States Air Force (USAF), and also saw service with the British Royal Navy, the French Air Force, the Republic of Vietnam Air Force (VNAF), and others. It remained in U.S. service until the early 1970s, and was replaced in the U.S. by the Fairchild-Republic A-10 Thunderbolt II.
Design and development
The piston-engined Skyraider was designed during World War II to meet United States Navy requirements for a carrier-based, single-seat, long-range, high performance dive/torpedo bomber, to follow-on from earlier types such as the Curtiss SB2C Helldiver and Grumman TBF Avenger.[3] Designed by Ed Heinemann of the Douglas Aircraft Company, prototypes were ordered on 6 July 1944 as the XBT2D-1. The XBT2D-1 made its first flight on 18 March 1945 and in April 1945, the USN began evaluation of the aircraft at the Naval Air Test Center (NATC).[4] In December 1946, after a designation change to AD-1, delivery of the first production aircraft to a fleet squadron was made to VA-19A.[5]
The AD-1 was built at Douglas' El Segundo plant in Southern California. In his memoir The Lonely Sky, test pilot Bill Bridgeman describes the routine yet sometimes hazardous work of certifying AD-1s fresh off the assembly line at a rate of two aircraft per day for delivery to the U.S. Navy in 1949 and 1950.[6]
A Douglas XBT2D-1 Skyraider prototype.
The low-wing monoplane design started with a Wright R-3350 Duplex-Cyclone radial engine, later upgraded several times. Its distinctive feature was large straight wings with seven hard points apiece. These gave the aircraft excellent low-speed maneuverability, and enabled it to carry a large amount of ordnance over a considerable combat radius and loiter time for its size, comparable to much heavier subsonic or supersonic jets. The aircraft was optimized for the ground-attack mission and was armored against ground fire in key locations unlike faster fighters adapted to carry bombs, such as the Vought F4U Corsair or North American P-51 Mustang, which were retired by U.S. forces before the 1960s.
Shortly after Heinemann began design of the XBT2D-1, a study was issued that showed for every 100 lb (45 kg) of weight reduction, the takeoff run was decreased by 8 ft (2.4 m), the combat radius increased by 22 mi (35 km) and the rate-of-climb increased by 18 ft/min (0.091 m/s). Heinemann immediately had his design engineers begin a program for finding weight-saving on the XBT2D-1 design, no matter how small. Simplifying the fuel system resulted in a reduction of 270 lb (120 kg); 200 lb (91 kg) by eliminating an internal bomb bay and hanging the bombs, drop tanks and rockets from the wings or fuselage; 70 lb (32 kg) by using a fuselage dive brake; and 100 lb (45 kg) by using an older tailwheel design. In the end, Heinemann and his design engineers found over 1,800 lb (820 kg) of weight savings on the original XBT2D-1 design.[7]
The Navy AD series was initially painted in ANA 623 Glossy Sea Blue, but during the 1950s following the Korean War, the color scheme was changed to light gull grey (FS26440) and white (FS27875). Initially using the gray and white Navy pattern, by 1967 the USAF began to paint its Skyraiders in a camouflaged pattern using two shades of green, and one of tan.
An A-1J of VA-176 loaded with ordnance for a mission in Vietnam in 1966.
Used by the USN over Korea and Vietnam, the A-1 was a primary close air support aircraft for the USAF and VNAF during the Vietnam War. The A-1 was famous for being able to take hits and keep flying. There was added armor plating around the cockpit area for added pilot protection. It was replaced beginning in the mid-1960s by the Grumman A-6 Intruder as the Navy's primary medium-attack plane in supercarrier-based air wings; however Skyraiders continued to operate from the smaller Essex class carriers.
The Skyraider went through seven versions, starting with the AD-1, then AD-2 and AD-3 with various minor improvements, then the AD-4 with a more powerful R-3350-26WA engine. The AD-5 was significantly widened, allowing two crew to sit side-by-side (this was not the first multiple-crew variant, the AD-1Q being a two-seater and the AD-3N a three-seater); it also came in a four-seat night-attack version, the AD-5N. The AD-6 was an improved AD-4B with improved low-level bombing equipment, and the final production version AD-7 was upgraded to a R-3350-26WB engine.
For service in Vietnam, USAF Skyraiders were fitted with the Stanley Yankee extraction system,[8] which acted in a similar manner to an ejection seat, though with a twin rocket pulling the escaping pilot from the cockpit.
In addition to serving during Korea and Vietnam as an attack aircraft, the Skyraider was modified to serve as a carrier-based airborne early warning aircraft, replacing the Grumman TBM-3W Avenger. It fulfilled this function in the USN and Royal Navy, being replaced by the Grumman E-1 Tracer and Fairey Gannet, respectively, in those services.[9]
Skyraider production ended in 1957 with a total of 3,180 having been built. In 1962, the existing Skyraiders were redesignated A-1D through A-1J and later used by both the USAF and the Navy in the Vietnam War.
Operational history
Korean War
An AD-4 Skyraider taking off from USS Princeton (CV-37) during the Korean War
The Skyraider was produced too late to take part in World War II, but became the backbone of United States Navy aircraft carrier and United States Marine Corps (USMC) strike aircraft sorties in the Korean War (1950–1953), with the first ADs going into action from Valley Forge with VA-55 on 3 July 1950.[10] Its weapons load and 10-hour flying time far surpassed the jets that were available at the time.[9] On 2 May 1951, Skyraiders made the only aerial torpedo attack of the war, hitting the Hwacheon Dam, then controlled by North Korea.[11]
On 16 June 1953, a USMC AD-4 from VMC-1 piloted by Major George H. Linnemeier and CWO Vernon S. Kramer shot down a Soviet-built Polikarpov Po-2 biplane, the only documented Skyraider air victory of the war.[12] AD-3N and -4N aircraft carrying bombs and flares flew night-attack sorties, and radar-equipped ADs carried out radar-jamming missions from carriers and land bases.[9]
During the Korean War, AD Skyraiders were flown only by the U.S. Navy and U.S. Marine Corps, and were normally painted in dark navy blue. It was called the "Blue Plane" by enemy troops.[13] Marine Corps Skyraiders suffered heavy losses when used in low-level close-support missions. To allow low-level operations to continue without unacceptable losses, a package of additional armor was fitted, consisting of 0.25–0.5 inches (6.4–12.7 mm) thick external aluminum armor plates fitted to the underside and sides of the aircraft's fuselage. The armor package weighed a total of 618 pounds (280 kg) and had little effect on performance or handling.[14] A total of 128 Navy and Marine AD Skyraiders were lost in the Korean War – 101 in combat and 27 to operational causes. Most operational losses were due to the tremendous power of the AD. ADs that were "waved-off" during carrier recovery operations were prone to perform a fatal torque roll into the sea or the deck of the aircraft carrier if the pilot mistakenly gave the AD too much throttle. The torque of the engine was so great that it would cause the aircraft to rotate about the propeller and slam into the sea or the carrier.
Cathay Pacific VR-HEU incident
On 26 July 1954, two Douglas Skyraiders from the aircraft carriers USS Philippine Sea and Hornet shot down two Chinese People's Liberation Army Air Force La-11s off the coast of Hainan Island while searching for survivors after the shooting down of a Cathay Pacific Skymaster airliner three days previously, by La-9s.[15]
Vietnam War
A 1st SOS A-1E carrying a BLU-72/B, 1968.
A 602nd SOS A-1H in June 1970.
As American involvement in the Vietnam War began, the A-1 Skyraider was still the medium attack aircraft in many carrier air wings, although it was planned to be replaced by the A-6A Intruder as part of the general switch to jet aircraft. Skyraiders from Constellation and Ticonderoga participated in the first U.S. Navy strikes against North Vietnam on 5 August 1964 as part of Operation Pierce Arrow in response to the Gulf of Tonkin Incident, striking against fuel depots at Vinh, with one Skyraider from Ticonderoga damaged by anti-aircraft fire, and a second from Constellation shot down, killing its pilot.[16][17]
During the war, U.S. Navy Skyraiders shot down two North Vietnamese Air Force (NVAF) Mikoyan-Gurevich MiG-17 jet fighters: one on 20 June 1965, a victory shared by Lieutenant Clinton B. Johnson and Lieutenant, junior grade Charles W. Hartman III of VA-25;[18] and one on 9 October 1966 by LTJG William T. Patton of VA-176.[12] Using their cannons, this was the first gun kill of Vietnam. While on his very first mission, Navy pilot LTJG Dieter Dengler took damage to his A-1H over Vietnam on 1 February 1966, and crash-landed in Laos.[19]
As they were released from U.S. Navy service, Skyraiders were introduced into the Republic of Vietnam Air Force (VNAF). Skyraiders were also used by Air Force Special Operations Command for search and rescue air cover. They were also used by the USAF to perform one of the Skyraider's most famous roles: the "Sandy" helicopter escort on combat rescues.[20][21] On 10 March 1966, USAF Major Bernard F. Fisher flew an A-1E mission and was awarded the Medal of Honor for rescuing Major "Jump" Myers at A Shau Special Forces Camp.[22] USAF Colonel William A. Jones, III piloted an A-1H on 1 September 1968 mission for which he was awarded the Medal of Honor. In that mission, despite damage to his aircraft and suffering serious burns, he returned to his base and reported the position of a downed U.S. airman.[22]
A-1E Skyraiders fly in formation over South Vietnam on way to target on 25 June 1965. The aircraft are assigned to the 34th Tactical Group, based at Biκn Hςa, South Vietnam.
After November 1972, all A-1s in U.S. service in Southeast Asia were transferred to the Republic of Vietnam Air Force (VNAF). The Skyraider in Vietnam pioneered the concept of tough, survivable aircraft with long loiter times and large ordnance loads. The USAF lost 201 Skyraiders to all causes in Southeast Asia, while the Navy lost 65 to all causes. Of the 266 lost A-1s, five were shot down by surface-to-air missiles (SAMs), and three were shot down in air-to-air combat; two by North Vietnamese MiG-17s.[23]
On the night of 29 August 1964, the first A-1E Skyraider was shot down and the pilot killed near Bien Hoa Air Base; it was flown by Capt. Richard D. Goss from the 1st Air Commando Squadron, 34th Tactical Group. The second A-1 was shot down on 29 April 1966, and the third A-1, Pilot Capt. Grant N. Tabor, was lost on 19 April 1967; both were from the 602 Air Commando Squadron (ACS). The fourth A-1 Skyraider was from Navy Squadron VA-25 flying a ferry flight from Cubi Point (Philippines) to Coral Sea and was lost to two Chinese MiG-17 on 14 February 1968. Lieutenant (j.g.) Joseph P. Dunn, USN, had flown too close to the Chinese held island of Hainan, and had been intercepted. Lieutenant Dunn's A-1H Skyraider 134499 (Canasta 404) was the last U.S. Navy A-1 lost in the war. He was observed to survive the ejection and deploy his raft, but was never found. Initially listed as MIA, he is now listed as KIA and posthumously promoted to the rank of Commander. Shortly thereafter, A-1 Skyraider naval squadrons transitioned to the A-6 Intruder, A-7 Corsair II or Douglas A-4 Skyhawk.[citation needed]
In contrast to the Korean War, fought a decade earlier, the U.S. Air Force used the naval A-1 Skyraider for the first time in Vietnam. As the Vietnam War progressed, USAF A-1s were painted in camouflage, while USN A-1 Skyraiders were gray/white in color; again, in contrast to the Korean War, when A-1s were painted dark blue.
A-1H "Paper Tiger II" carrying the toilet bomb in October 1965
In October 1965, to highlight the dropping of the six millionth pound of ordnance, Commander Clarence J. Stoddard of Attack Squadron 25 (VA-25), flying an A-1H, dropped a special, one-time-only object in addition to his other munitions – a toilet.[24]
An A-1H Skyraider of the VNAF 516th Fighter Squadron being loaded with napalm at Da Nang AB in 1967.
The A-1 Skyraider was the close air support workhorse of the Republic of Vietnam Air Force (VNAF) for much of the Vietnam War. The U.S. Navy began to transfer some of its Skyraiders to the VNAF in September 1960, replacing the VNAF's older Grumman F8F Bearcats. By 1962 the VNAF had 22 of the aircraft in its inventory,[25] and by 1968 an additional 131 aircraft had been received. Initially Navy aviators and crews were responsible for training their South Vietnamese counterparts on the aircraft, but over time responsibility was gradually transferred to the USAF.
The initial trainees were selected from among VNAF Bearcat pilots who had accumulated 800 to 1200 hours flying time. They were trained at NAS Corpus Christi, Texas, and then sent to NAS Lemoore, California for further training. Navy pilots and crews in Vietnam checked out the Skyraiders that were being transferred to the VNAF, and conducted courses for VNAF ground crews.[26]
Over the course of the war, the VNAF acquired a total of 308 Skyraiders, and was operating six A-1 squadrons by the end of 1965. These were reduced during the period of Vietnamization from 1968 to 1972, as the U.S. began to supply the South Vietnamese with more modern close air support aircraft, such as the Cessna A-37 and Northrop F-5, and at the beginning of 1968, only three of its squadrons were flying A-1s.[27]
As the U.S. ended its direct involvement in the war, it transferred the remainder of its Skyraiders to the South Vietnamese, and by 1973, all remaining Skyraiders in U.S. inventories had been turned over to the VNAF.[28] Unlike their American counterparts, whose combat tours were generally limited to 12 months, individual South Vietnamese Skyraider pilots ran up many thousands of combat hours in the A-1, and many senior VNAF pilots were extremely skilled in the operation of the aircraft.[29]
United Kingdom
Four Royal Navy Douglas Skyraider AEW.1s from D Flight 849 Naval Air Squadron, based at Royal Naval Air Station Culdrose, in flight in the 1950s
The Royal Navy acquired 50 AD-4W early warning aircraft in 1951 through the Military Assistance Program. All Skyraider AEW.1s were operated by 849 Naval Air Squadron, which provided four-plane detachments for the British carriers. One flight aboard HMS Bulwark took part in the Suez Crisis in 1956. 778 Naval Air Squadron was responsible for the training of the Skyraider crews at RNAS Culdrose.[30]
In 1960, the Fairey Gannet AEW.3 replaced the Skyraiders, using the APS-20 radar of the Douglas aircraft. The last British Skyraiders were retired in 1962.[30] In the late 1960s, the APS-20 radars from the Skyraiders were installed in Avro Shackleton AEW.2s of the Royal Air Force which were finally retired in 1991.
Sweden
Fourteen British AEW.1 Skyraiders were sold to Sweden to be used by Svensk Flygtjδnst AB between 1962 and 1976. All military equipment was removed and the aircraft were used as target tugs with the Swedish armed forces.[30]
France
The French Air Force bought 20 ex-USN AD-4s as well as 88 ex-USN AD-4Ns and five ex-USN AD-4NAs with the former three-seaters modified as single-seat aircraft with removal of the radar equipment and the two operator stations from the rear fuselage. The AD-4N/NAs were initially acquired in 1956 to replace aging Republic P-47 Thunderbolts in Algeria.[31]
The Skyraiders were first ordered in 1956 and the first was handed over to the French Air Force on 6 February 1958 after being overhauled and fitted with some French equipment by Sud-Aviation. The aircraft were used until the end of the Algerian war. The aircraft were used by the 20e Escadre de Chasse (EC 1/20 "Aures Nementcha", EC 2/20 "Ouarsenis" and EC 3/20 "Oranie") and EC 21 in the close air support role armed with rockets, bombs and napalm.
The Skyraiders had only a short career in Algeria, but they nonetheless proved to be the most successful of all the ad hoc COIN aircraft deployed by the French. The Skyraider remained in limited French service until the 1970s.[31] They were heavily involved in the civil war in Chad, at first with the Armιe de l'Air, and later with a nominally independent Chadian Air Force staffed by French mercenaries. The aircraft also operated under the French flag in Djibouti and on the island of Madagascar. When France at last relinquished the Skyraiders it passed the survivors on to client states, including Gabon, Chad, Cambodia and the Central African Republic.[32] (several aircraft from Gabon and Chad have been recovered recently by French warbird enthusiasts and entered on the French civil register).
The French frequently used the aft station to carry maintenance personnel, spare parts and supplies to forward bases. In Chad they even used the aft station for a "bombardier" and his "special stores" – empty beer bottles – as these were considered as non-lethal weapons, thus not breaking the government-imposed rules of engagement, during operations against Libyan-supported rebels in the late 1960s and early 1970s.
Variants
The XBT2D-1 in 1945
A VC-35 AD-1Q in the late 1940s
A VC-33 AD-3Q, AD-4N, and AD-5N in 1955
An AD-4W AEW-aircraft landing on the USS Leyte
A VMA-331 AD-5 in flight
An EA-1F (AD-5Q) ECM-aircraft, BuNo 135010, of CVW-9 in 1966
A VAW-11 AD-5W aboard USS Kearsarge, 1958
AD-6s from U.S. Navy Attack Squadron 42.
XBT2D-1
Single-seat dive-bomber, torpedo-bomber prototype for the U.S. Navy.
XBT2D-1N
Three-seat night attack prototypes; only three aircraft built.
XBT2D-1P
Photographic reconnaissance prototype; only one built.
XBT2D-1Q
Two-seat electronics countermeasures prototype; one aircraft only.
BT2D-2 (XAD-2)
Upgraded attack aircraft; one prototype only.
AD-1
The first production model; 242 built.
AD-1Q
Two-seat electronic countermeasures version of the AD-1; 35 built.
AD-1U
AD-1 with radar countermeasures and tow target equipment, no armament and no water injection equipment.
XAD-1W
Three-seat airborne early warning prototype. AD-3W prototype; one aircraft only.
AD-2
Improved model, powered by 2,700 hp (2,000 kW) Wright R-3350-26W engine; 156 built.
AD-2D
Unofficial designation for AD-2s used as remote-control aircraft, to collect and gather radioactive material in the air after nuclear tests.
AD-2Q
Two-seat electronics countermeasures version of the AD-2; 21 built.
AD-2QU
AD-2 with radar countermeasures and target towing equipment, no armament and no water injection equipment; one aircraft only.
XAD-2
Similar to XBT2D-1 except engine, increased fuel capacity.
AD-3
Proposed turboprop version, initial designation of A2D Skyshark.
AD-3
Stronger fuselage, improved landing gear, new canopy design; 125 built.
AD-3S
Anti-submarine warfare model; only two prototypes were built.
AD-3N
Three-seat night attack version; 15 built.
AD-3Q
Electronics countermeasures version, countermeasures equipment relocated for better crew comfort; 23 built.
AD-3QU
Target towing aircraft, but most were delivered as the AD-3Q.
AD-3W
Airborne early warning version; 31 built.
XAD-3E
AD-3W modified for ASW with Aeroproducts propellor
AD-4
Strengthened landing gear, improved radar, G-2 compass, anti-G suit provisions, four 20 mm (.79 in) cannon and 14 Aero rocket launchers, capable of carrying up to 50 lb (23 kg) of bombs; 372 built.
AD-4B
Specialized version designed to carry nuclear weapons, also armed with four 20 mm cannon; 165 built plus 28 conversions.
AD-4L
Equipped for winter operations in Korea; 63 conversions.
AD-4N (A-1D)
Three-seat night attack version; 307 built.
AD-4NA
Designation of 100 AD-4Ns without their night-attack equipment, but fitted with four 20 mm (0.79 in) cannon, for service in Korea as ground-attack aircraft.
AD-4NL
Winterized version of the AD-4N; 36 conversions.
AD-4Q
Two-seat electronic countermeasures version of the AD-4; 39 built.
AD-4W
Three-seat airborne early warning version; 168 built. A total of 50 AD-4Ws were transferred to the Royal Navy as Skyraider AEW Mk 1.
AD-5 (A-1E)
Side-by-side seating for pilot and co-pilot, without dive brakes; 212 built.
AD-5N (A-1G)
Four-seat night attack version, with radar countermeasures; 239 built.
AD-5Q (EA-1F)
Four-seat electronics countermeasures version; 54 conversions.
AD-5S
One prototype to test Magnetic anomaly detector (MAD) anti-submarine equipment.
AD-5W (EA-1E)
Three-seat airborne early warning version with an APS-20 radar installed; 218 were built.
UA-1E
Utility version of the AD-5.
AD-6 (A-1H)
Single-seat attack aircraft with three dive brakes, centerline station stressed for 3,500 lb (1,600 kg) of ordnance, 30 in (760 mm) in diameter, combination 14/30 in (360/760 mm) bomb ejector and low/high altitude bomb director; 713 built.
AD-7 (A-1J)
The final production model, powered by a R-3350-26WB engine, with structural improvements to increase wing fatigue life; 72 built.
Operators
Main article: List of Douglas A-1 Skyraider operators
Cambodia
Chad
France
Gabon
South Vietnam
Thailand
Sweden
United Kingdom
United States
Survivors
Main article: List of surviving Douglas A-1 Skyraiders
Specifications (A-1H Skyraider)
Line drawings for the AD-4 Skyraider.
Data from McDonnell Douglas Aircraft since 1920[33]
General characteristics
Crew: One
Length: 38 ft 10 in (11.84 m)
Wingspan: 50 ft 0Ό in (15.25 m)
Height: 15 ft 8Ό in (4.78 m)
Wing area: 400.3 ft² (37.19 m²)
Empty weight: 11,968 lb (5,429 kg)
Loaded weight: 18,106 lb (8,213 kg)
Max. takeoff weight: 25,000 lb (11,340 kg)
Powerplant: 1 Χ Wright R-3350-26WA radial engine, 2,700 hp (2,000 kW)
Performance
Maximum speed: 322 mph (280 kn, 518 km/h) at 18,000 ft (5,500 m)
Cruise speed: 198 mph (172 kn, 319 km/h)
Range: 1,316 mi (1,144 nmi, 2,115 km)
Service ceiling: 28,500 ft (8,685 m)
Rate of climb: 2,850 ft/min (14.5 m/s)
Wing loading: 45 lb/ft² (220 kg/m²)
Power/mass: 0.15 hp/lb (250 W/kg)
Armament
Guns: 4 Χ 20 mm (0.79 in) AN/M3 autocannon
Hardpoints: 15 external hardpoints with a capacity of 8,000 lb (3,600 kg) and provisions to carry combinations of:
Other: bombs, torpedoes, mine dispensers, unguided rockets, and gun pods.[24]
Naming
The A-1 Skyraider received various nicknames including: "Spad" and "Super Spad" (derived from the aircraft's AD designation, its relative longevity in service and an allusion to the "Spad" aircraft of World War I), "Able Dog" (phonetic AD), "the Destroyer", "Hobo" (radio call sign of the USAF 1st Air Commando/1st Special Operations Squadron), "Firefly" (a call sign of the 602nd ACS/SOS), "Zorro" (the call sign of the 22nd SOS), "The Big Gun", "Old Faithful", "Old Miscellaneous", "Fat Face" (AD-5/A-1E version, side-by-side seating), "Guppy" (AD-5W version), "Q-Bird" (AD-1Q/AD-5Q versions), "Flying Dumptruck" (A-1E), "Sandy" (the 602nd ACS/SOS call sign for Combat Search And Rescue helicopter escort), and "Crazy Water Buffalo" (South Vietnamese nickname).[34][not in citation given]
Old 01-18-2018, 06:19 PM
  #15277
Wagon1
Wagon1's Avatar
Okay, long time lurker, new guesser. Please forgive me if this one has been done before...
1. This airplane uses the same (ish) engine as the B-17 and Brewster Buffalo.
2. Low wing monoplane
3. Production run of about 500
Old 01-18-2018, 11:10 PM
  #15278
Hydro Junkie
Hydro Junkie's Avatar
P-36
Old 01-19-2018, 06:34 AM
  #15279
Ernie P.
And if not the P-36, and assuming "about 500" means more then 400 and less than 600, how about the Curtiss SC Seahawk? Thanks; Ernie P.
Old 01-19-2018, 01:46 PM
  #15280
Wagon1
Wagon1's Avatar
Seriously? How do you get that correctly with those clues??? Well done Ernie.
Old 01-19-2018, 01:50 PM
  #15281
FlyerInOKC
FlyerInOKC's Avatar
Looks like Hydro and Ernie both got it. Now you two can fight it out on who is up. Good subject Wagon1! I hope you will continue to participate. I know I have learned a lot even from my wrong guesses.
Mike
Old 01-19-2018, 03:31 PM
  #15282
Ernie P.
Sir; first of all, welcome to the group. I hope you enjoy competing with us in answering the questions, and offering us a chance to compete with each other in answering your's. I think you'll enjoy the group; we all learn from each other and have fun at the same time.
Answering your question was, for this crowd, a fairly straightforward matter. The B-17 and Buffalo used the Pratt & Whitney R-1690 Hornet radial engine. So, how many other aircraft used that engine? And, of those, how many were low wing monoplanes? And, of those, how many had production runs around 500? It turns out only two or three military aircraft could qualify. Hydro Junkie grabbed the most likely, the P-36. So, I took the most likely of the other two. Easy, no?
Don't be discouraged, though. You'll pick it up pretty quickly. Choose your clues carefully, so as not to reveal too much, too quickly. Kind of like good striptease.
Okay; Since the gentleman named me, I'll have something up soon. Thanks; Ernie P.
Old 01-19-2018, 06:49 PM
  #15283
Ernie P.
As promised. I've been holding this one back for a while, since it's fairly easy to figure out. But I do think you'll find it interesting. Thanks; Ernie P.
What warbird do I describe?
Clues:
1. This aircraft served in WWI.
2. It was a single seat “scout” aircraft.
Old 01-19-2018, 07:13 PM
  #15284
FlyerInOKC
FlyerInOKC's Avatar
S.E. 2a?
Old 01-19-2018, 07:33 PM
  #15285
elmshoot
I had that in the cross hairs as well. My dad had many hundreds of hours flying the SC-1 in WW2 off the USS Chicago CA-36.
We had a appointment at noon so I didn't get a chance to confirm that as my answer.
He spoke quite highly of the plane, its outstanding performance. The plane they used for transition training was the Corsair.
I'd have to dig into his log book a bit more. I have quite a bit of information on the plane and someday i hope to do a 80" model of the plane.
Sparky
Fokker E1 (Eindecker)
Old 01-19-2018, 08:39 PM
  #15286
Hydro Junkie
So, which was it, the P-36 or the Seahawk?
For me, it was an easy jump from the B-17 and Buffalo to the P-36. Both the B-17 and Buffalo used the Curtis Wright radial. That took out one of the few planes that fit the next clue, being a low wing.
Clues 1 and 2 both took out the Wildcat since it was a mid wing powered by a P&W, though the later FM2 was fitted with a Wright radial
Clue 3, saying 500 were built fit the P-36 as well since it was reworked to use the Allison, becoming the P-40
Old 01-19-2018, 09:30 PM
  #15287
Ernie P.
Guys; the above quote is why I figured I was the correct responder. If I am mistaken, I apologize; but I thought the response from Wagon1 was pretty clear. Did I miss something? Thanks; Ernie P.
Old 01-19-2018, 09:32 PM
  #15288
Ernie P.
No correct answers thus far; but here's another clue to reward all the participation. Thanks; Ernie P.
Clues:
3. It was powered by a rotary engine.
Old 01-19-2018, 09:46 PM
  #15289
Ernie P.
Sparky
Now that's the kind of direct knowledge I love to see in this forum. Thanks, Sparky; Ernie P.
Old 01-20-2018, 06:23 AM
  #15290
Ernie P.
And a new clue for today. Thanks; Ernie P.
Clues:
4. Armament varied; usually one or two machine guns.
Old 01-20-2018, 11:16 AM
  #15291
Ernie P.
Well, okay; here's another clue. Thanks; Ernie P.
Clues:
5. It was a sesquiplane design.
Old 01-20-2018, 05:13 PM
  #15292
Ernie P.
Okay; one more. Thanks; Ernie P.
Clues:
6. The wing area was just under fifteen (15) square meters.
Old 01-21-2018, 07:29 AM
  #15293
Ernie P.
And a Sunday morning clue. And BTW; Clue (6) was a big one. Thanks; Ernie P.
Clues:
7. The design was sound, but production was delayed by engine production problems.
Old 01-22-2018, 03:23 AM
  #15294
Ernie P.
Morning clue. Thanks; Ernie P.
Clues:
8. By the time the plane was available in significant numbers, it was on the verge of being obsolescent.
Old 01-22-2018, 06:15 AM
  #15295
FlyerInOKC
FlyerInOKC's Avatar
Sopwith 1-1/2 Strutter?
Mike
Old 01-22-2018, 06:34 AM
  #15296
Ernie P.
Not the 1-1/2 Strutter, FlyerInOKC; that plane doesn't match clues (5) and (6). But, you've earned a bonus clue for your efforts. Thanks; Ernie P.
Clues:
9. It was a “vee strutter”.
Old 01-22-2018, 06:49 AM
  #15297
FlyerInOKC
FlyerInOKC's Avatar
How about the Nieuport 24?
Old 01-22-2018, 07:07 AM
  #15298
Ernie P.
Not the Nieuport 24, Sir; but again you have earned a bonus clue for your efforts. And, again, clue (6) is a big one. Thanks; Ernie P.
Clues:
10. It served as an advanced trainer after being withdrawn from front line service.
Old 01-22-2018, 08:02 AM
  #15299
Hydro Junkie
Okay, how about this:
The French Caudron G.3
Old 01-22-2018, 09:05 AM
  #15300
Ernie P.
Not the Caudron G.3, Hydro Junkie; but here's another clue for you. You guys are dancing all around what I would have thought was the obvious answer; which, of course, is not the correct answer. Again, clue (6) is an important one. Thanks; Ernie P.
Clues:
11. It was largely overshadowed by the arrival of a famous plane of much superior capability.
