ESM P47 Build
#226
I have about 80 flights on mine now (Evo 26ccm with 18X8 2-blade Mejzlik) , I actually did not reinforce the firewall at all, and upon inspection things look solid. No reinforcements of landing gear bay either (Sierra retracts).I had one hard land, early on, with a deadstickon climbout just after takeoff. No damage to the plane.Everything is still holding up just fine. HadI built it again, I would have done what you have done, glassing the inside of the firewall, instead of adding lead to the front. I like your engine choice, it will really haul the plane around with authority. Did youadd in more right thrust than what is built into the plane from ESM?
I am just building up mine. You mentioned that ESM have a built in right thrust to the fire wall? The f/wall is monolithic to the fuse isn't it? Would you kindly elaborate a bit more, please? I was planning to put in some washers top and left sides as we normally do for down and right thrust. So from what you've said, I only need down thrust, correct?
Cheers
Mo
#227
Esm p47d jug
Hey Hans, sorry to hear that but of course you have your reasons...
Also, I understand there is a built in right thrust on the firewall. Is this correct? Further, is there a a down thrust also built in?
Cheers
Mo
Cheers
Mo
