canopy frames?
any ideas about how to make canopy frames ? i really dont have a clue
RE: canopy frames?
Fiberglass layed up over your canopy, then remove the glass layup, trim to shape c
RE: canopy frames?
1 Attachment(s)
Probably the fiberglass canopy frame is the easiest way how to do it. Here are some pictures. You can make a fiberglass form, or make the frame on the model, which is made from some polystyrene foam (it is in the last three pictures).
RE: canopy frames?
Invertmast is right, thats a great way. But don't forget a good release agent!<div>
</div><div>Whit</div> |
RE: canopy frames?
what would be a good release agent ?
RE: canopy frames?
Wax and pva
If its a simple canopy (like FW190, me109, etc) G10 works really well to |
RE: canopy frames?
Go to the hobby shop for some "plasticstruck.
RE: canopy frames?
1 Attachment(s)
ABS plastic. Carefully cut you can pull it off. This one is small, 1/10 or 1/11 scale.
Charles |
RE: canopy frames?
Another way is to use a second canopy to cut the frame out of, sand, primer and paint accordingly.
RE: canopy frames?
That IS another canopy, pulled from the same mould, just used ABS.
Charles |
RE: canopy frames?
Or just build up the frames with primer and then paint. On many aircraft the glass is flush or nearly flush with the frames and thus they do not need to stand proud of the canopy very much if at all.
RE: canopy frames?
ORIGINAL: Chad Veich Or just build up the frames with primer and then paint. On many aircraft the glass is flush or nearly flush with the frames and thus they do not need to stand proud of the canopy very much if at all. Chad, I believe you are correct. A simple tape edge from a coat of paint is about the correct thickness. Anything else is probably overkill. In my case with this model, I wanted the canopy exhagerated. All the features are a bit exhagerated. It's also CL. Charles |
RE: canopy frames?
ORIGINAL: Avaiojet Chad, I believe you are correct. A simple tape edge from a coat of paint is about the correct thickness. Anything else is probably overkill. In my case with this model, I wanted the canopy exhagerated. All the features are a bit exhagerated. It's also CL. |
RE: canopy frames?
Chad,
Clever guy! Kudos! Yes, a bit of the Mig-3. The model blossomed into a Mig-3. It wasn't planned, but I'm happy with the results. Charles |
| All times are GMT -8. The time now is 07:52 AM. |
