RCU Forums
-   RC Warbirds and Warplanes (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/)
-   -   Panel lines help! (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/3061032-panel-lines-help.html)
Ruudje 06-10-2005 12:15 PM
Panel lines help!
Hi,
I bought some 1/64" tape to make panel lines.
I was just wondering... How many layers of primer do I have to spray over them before applying color?
Anyone any experience...!?
Rudy
Irish R.Seer 06-10-2005 03:07 PM
RE: Panel lines help!
1 Attachment(s)
I sprayed two coats of primer over the chart tape. removed the tape and rubbed the lines with fine wet and dry paper (wet). Seemed to work OK.
Bill
mR JoLLy 06-10-2005 04:47 PM
1 Attachment(s)
Rudy if it's high build primer 2 good coats will be fine. If it is standard aerosol primer 3 will be necessary. Remember also there is no need to prime the entire surface, just spray along the line of the tape, the fan overspray will feather nicely.
Attached not on my web site but shows the clarity of 3 coats from a can!
Good look.
PS mark out both top and bottom wing before you apply the tape. I did top and bottom separately and made some minor errors in alignment.
Chad Veich 06-10-2005 04:49 PM
I use two heavy coats of primer also, just over the tapes and maybe an inch or so either side rather than over the entire surface of the model. I then wet sand the primer back to reveal the tape which helps it to come off cleaner. (leaves a less jagged edge)
Ruudje 06-11-2005 04:36 AM
As always: thanks guys!
bosssman 06-11-2005 12:40 PM
very, very good points. Keep in mind, that prior to applying the panel lines, your surface should be "paint ready", meaning all grain/seems are filled and ready to receive color coats. The "panel primer" is just that - an illusion that represents one solid panel meeting another solid panel. It is totally unecessary to fill in with primer between the chart pak tape. Primer is pretty heavy stuff and as such, most should be sanded off leaving a smooth, level surface. Myself, I prefer polyester primers that are catalyst based as they are EXTREMELY high fill and dont require as much as some of the other primers out there. Of course, spraying equipment is necessary, but if you stay in this hobby, an inexpensive 2 hp compressor and small spray gun and air brush are a must. good luck on your project!!!
randy
CarverTripp 06-11-2005 01:26 PM
Mr Jolly,
Nice pics, could you tell me how did you apply your rivots, are they glue or pressed in?
Carver
grbaker 06-11-2005 01:38 PM
mR JoLLy
Very nice work!!!
mR JoLLy 06-11-2005 04:18 PM
1 Attachment(s)
It's my first attempt at a scale model having built "none scale" many times. The Spitfire in the pictures is a Mick Reeves 1/6 scale and is almost ready to be let loose, but not for a while. I am reasonable happy with the result.
Carver the rivets are applied with a soldering iron and took a 3 weeks of evenings to prepare and apply to the fuselage and wing.
I have posted a link on this forum to my web site before, but here it is again. You can see the entire build bang up to date.
[link=http://www.hbc.pwp.blueyonder.co.uk/models/spitfire/index.htm]http://www.hbc.pwp.blueyonder.co.uk/models/spitfire/index.htm[/link]
The next one will be better ;)
Just need to dirty this one up a little to make it less crisp!
JoLLy
Ruudje 08-09-2005 12:15 PM
Hi guys!
I now sprayed FOUR coats on a test peace and pult the tape off... Not much of a panelline visible! I thought I sprayed on a pretty thick coat!
How about applying a coat with a roller?
Or will the lines show up when I put color on?
Thanks!
Dai Phan 08-10-2005 11:16 AM
1 Attachment(s)
Hello,
Have ever thought about "forced panelling" technique used in plastic modeling? Basically, you lay a masking tape anterior to the panel lines then using an almost dry brush with darker color of the main frame brushing AGAINST the tape. The paint particles will be "sweept up" against the tape producing a nice sharp panel line. This technique works great on 1/5- 1/6 scale planes. Anything larger will need the technique outlined in previous posts. I have done so on my O-1 Bird Dog and it looks very convincing. DP
Ruudje 08-10-2005 12:13 PM
Hi Dai Phan!
Your plain looks nice!
I tried something like this on my P51D and it also worked fine... But I thought I'd use a new technique with the chart tape this time...
Thanks for the advice though...
kqutob 10-10-2005 04:53 PM
Hi all
I'm about to start a TF FW190. I'm looking around for 1/64"& 1/32" tape but none of the major retailers carry any. Where can I find it .
Is there any alternative methods for creating panel lines . I'm thinking maybe the careful use of a reamer could work. Please advise
mR JoLLy 10-11-2005 01:57 AM
The tape you are looking for is from a company called "Letraset" and the tape is branded "Letraline".
I have 1/64" (0.4mm) with part number 471.
Looking at the main web site the 0.4mm tape is no longer available, next best is 0.5mm which should be OK. I am sure with more than 2 minutes on the net with this information you should be able to find some. You might have to get it in from overseas.
[link=http://www.letraset.com/uk/template1.asp?catid=3495&viewtype=all]http://www.letraset.com/uk/template1.asp?catid=3495&viewtype=all[/link]
JoLLy
Editing this because I found the 0.4mm tape [link=http://www.letraset.com/uk/template1a.asp?catid=3529&id=3530]http://www.letraset.com/uk/template1a.asp?catid=3529&id=3530[/link] ;)
Ruudje 10-11-2005 03:46 AM
1 Attachment(s)
Thanks Jolly!
I ordered the 0.4mm tape just before it wasn't available anymore :)
The panellines are on by the way!
kqutob 10-11-2005 03:10 PM
Thanks for the info Jolly
I located the local agent of Letraset and called them . I should get the tape in the near future.
Thanks again
mR JoLLy 10-11-2005 03:15 PM
kqutob no problem at all. That is why this forum is here :)
Rudje
Looking good old boy! How far off is it from flying ??
JoLLy
Ruudje 10-12-2005 03:44 AM
Hi Jolly,
Still a long way to go before this baby is airworthy!
It will probably not fly before spring 2006.
But it’s okay, this gives me the time to practice a little more with the P51D. The last few flights weren’t that great and I have to do some repair on my landing gear first…
Takeoffs and landings is always difficult because of the short fuse and short distance between CG and wheel axle…
Arthur K 10-13-2005 01:06 PM
Hi guy's I found some 1 /64 and 1/32 chart tape from a company called chart pack I think it is the same as ltraset and you can find it at Architect supply stores
Although the 1 /64 is in my opinion too thin but the 1/32nd seems perfect
