RCU Forums
-   RC Warbirds and Warplanes (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/)
-   -   Best Technique for Hinging Split Flaps? (https://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/5216602-best-technique-hinging-split-flaps.html)
TLH101 01-05-2007 06:26 PM
1 Attachment(s)
Anyone have a good technique for drilling the hole in "exactly" the right place to "bottom" hinge split flaps? You know, all the holes lined up on the same plane.:eek:
Hope my sketch helps.
saramos 01-05-2007 07:16 PM
RE: Best Technique for Hinging Split Flaps?
1 Attachment(s)
I used Robart hinges for the split flaps on my TF Spitfire. If I were to do it again, I think that I would strongly consider using a pinned hinge. As for alignment for drilling the hinges, here's something that might work, make some triangle wedges which will give a flat surface perpendicular to the direction you are drilling and then use a drill press with a fence.
Scott
