warbird trailer
What is the best way to set up racks on a 6x12ft enclosed trailer for hauling warbirds so they do not get damaged?, photos would be helpful as well, thanks!.
RE: warbird trailer
ORIGINAL: geoflying What is the best way to set up racks on a 6x12ft enclosed trailer for hauling warbirds so they do not get damaged?, photos would be helpful as well, thanks!. http://www.rcuniverse.com/forum/m_11..._1/key_/tm.htm |
RE: warbird trailer
1 Attachment(s)
Geo,
I use a wall-mount rack system as indicated. Each inner bracket (in contact with the fuselage) is bolted into the steel support bracket, then into the trailer vertical framing). Made from 1/2" plywood, they're cut to the plane's former profile, taken off the plans; fits like a glove. Not one transporting incident in nine years. I fit five Ziroli/Meister-size models and all support equipment within this 6' X 12' trailer. NICK |
RE: warbird trailer
Are u using bungy cord or velcro to fasten straps the fuse down on the racks? thanks for the info!.
RE: warbird trailer
1" velcro is used.
NICK |
