Broken Air Fill Valve
1 Attachment(s)
This one-way air fill valve has been sitting unused for a few years. Now that it's time to use it, I discover that it doesn't hold the pressure. The pressurized air that I hand pumped all the way to 100 psi escapes freely.
I opened it up and I think there is a piece missing inside. The question for you guys, what does that piece look like? Can someone please open up theirs and take a picture of that piece inside? Maybe I can make a replacement, instead of buying a whole new valve. Thanks in advance, Juice |
RE: Broken Air Fill Valve
If it were me I would buy a better air fill from Sierra or Robart. Sierra has the best air fill and it is like a tire fill with the button.
Barry |
Any clue what brand that is??
I looked through my Box-o-junk and don't have one of those,,, I'm jealous |
I believe its an older robart valve, it takes a rubber disc inside to seal, as I recall they dont seem to be very reliable.
Yes, it is the older Robart valve. I bought it back when they one-way valve and the attachment for the fill chuck were two seperate pieces.
It makes sense for a rubber disc to go inside. I'll try something tonight, or else I'll head to the hobby shop this weekend. Thanks for everyone's help. |
I think its Romaire, and it was one of two pieces, one being a check valve, and the other the fill valve. You have only one of the two parts.
Bob Violet models makes a really good fill valve that has a shrader fitting, like on your car tire, it's a very high quality one. |
Hi i use the one way valve from old peddle bike inner tubes just cut the valve out clean up the rubber from the outside of the valve and you have a surface to solder on a mounting plate, they are a bit long so i recess them into the fuse.
Also when soldering the mounting plate unscrew the inner workings or you will melt the rubber inside. I have been using them for years and no problems. To blow the retracts up i use a small cheap 12V. car tire compressor that you keep in the car for emergency use. You can buy the compressor in a Auto spares store you can get a cheap one over here for about $20, the Auto compressor connector fits directly onto the bike valve so no problem there. The bike and car valves are the same. |
1 Attachment(s)
A Ball Needle achieves the same purpose, I've used one for years with the same type of 12 volt pump
It doesn't look like the Rhom Air unit I have.
This is what I have standardised for my retract equipped models. http://www3.towerhobbies.com/cgi-bin...?&I=LXET31&P=7 I saw an thread detailing how to use a tyre valve stem adapted to the size tube retracts use by soldering nipples & adapters but for less than 20 bucks why fiddle about making something up? - John. |
