wickid weapon that may be possable to make
i havent build one of there boats yet but there is one weapon i will try and put on it...as hight preasure sand connon
simular to what they use from power coating
it will work by two tubes connection one with air flow from tank and outher to the sand store this will hopefully shoot the sand out at high speed and wear a hole in the oppisitions boat hull
in theory it will work but can you see it happening??
RE: wickid weapon that may be possable to make
I don't think you would have enough time on target to put a hole in a boat. We are building some BB cannons as well as ball bearing cannons for our boat. That way you get a hit and a hole the other guy sinks.
In a good tactical battle, there is usually time for three good shots, then the target has usually turned away. If by some chance your target thinks he has the advantage, a running exchange will occur.
Since most of the clubs use try to represent weapons of the day, I am not sure what a sand blasting
cannon would be representing.
MN
ORIGINAL: Umi_Ryuzuki
JM
