Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Sumo
Old 03-07-2011 | 09:50 AM
Default Sumo
Yup went and got me the 1/24 scale sumo truck. Wondering if i would like a 120 mah airplane 1s lipo in it will that overpower the unit or would 2 since it would then be about 7.4 volts where it currently is 6 volts with 4 aa at 1.5 volts each.
http://cgi.ebay.com/EFLB1201S-E-flit...item4aa6fb4945
is the type i was thinking of using.
Old 03-07-2011 | 03:14 PM
Banned
Default RE: Sumo
how are you going to wire it in though?
Old 03-07-2011 | 05:09 PM
Default RE: Sumo
Buy the wire connector and connect it. as the helo that comes in has a wire to plug into that battery will just solder it onto the sumo.
Old 03-07-2011 | 05:12 PM
Banned
Default RE: Sumo
oh okay. well idk the answer to your question, but someone else might. i was just wondering how you would do that since AA connections are a little bit different.
Old 03-07-2011 | 06:32 PM
Default RE: Sumo
Hmm, a case could be made either way.  It's possible it will work.  I wanted to try some NiZn batts in it, then it would have been 6.4 volts which is even closer to it, however never got around to that experiment.
Old 03-07-2011 | 06:40 PM
Default RE: Sumo
figured the lipo and then try to work one of the outboard little brushless motors on some how. This will be a little down the road. Need to get the crawler together and the buggy finished before race season.
Old 03-07-2011 | 07:07 PM
Default RE: Sumo
Brushless motor is tougher. Brushed motors are DC, whereas brushless are 3 phase AC.
Old 03-07-2011 | 08:06 PM
Default RE: Sumo
i know loving the challenge first is lipo 1s conversion then ill think about brushless. But this will be mid summer till i get started just gather parts for that rainy day.
Old 03-07-2011 | 08:17 PM
nitrosportsandrunner's Avatar
Default RE: Sumo
1s lipo will be fine on the stock electronics. 2s lipo however messes with the stock ESC/rx. i tried it, and the throttle was all over the place.
Old 03-07-2011 | 08:38 PM
Default RE: Sumo
ok thanks nitro. will run them parallel then and go from there. leave it at 1s but but it to 240 mah.
Old 03-10-2011 | 02:57 PM
Default RE: Sumo
http://www.hobbyking.com/hobbyking/s...idProduct=4203
Brushless 130 size motor.
found and esc to run with it and looking for a new steering servo.
If this rain keeps up might get all projects completed soon.
