Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
engine cuts out at half a tank
Old 03-26-2012 | 12:37 PM
Default engine cuts out at half a tank
Hey guys so ive run into a problem, at about half a tank or just under half my engine quits, it will start again but it gives me trouble and dies again soon after, i have no idea whats happening as just a couple days ago i was going tank through tank finishing off the whole thing
any and all help is appreciated guys thank you!<br type="_moz" />
Old 03-26-2012 | 07:41 PM
Default RE: engine cuts out at half a tank
check for exhaust, fuel tank cap, and fuel tube leaks. Also try changing your glow plug if you haven't already.
Old 03-28-2012 | 02:54 AM
Is the engine HOT when it cuts out&gt;Too lean then......
Old 03-28-2012 | 07:52 AM
Thanks guys problem solved, first my exhaust had a leak at the manifold, gasket was bad where manifold meets engine's exhaust port, plus my LSN was a little clogged causeing low pressure and at half a tank would cut off, got a new gasket and dissassembeled the carb cleaned it and put it back together runs like a dream! thanks
