volcano epx pro 8.4v?
Hello, i just bought a volcano epx pro, i was just wondering if i can use an 8.4v nimh in the truck without damaging it. Ive searched but find alot of mixed answers. Any input would be greatly appreciated. thanks.
aj.
aj.
Wondering if i can get some help again. im trying to run a tenergy 8.4v battery in my volcano epx pro. the battery has tamiya connector on it. the truck has banana 4.0. is there an adapter i can buy to do this or is it now possible. i search on google for it and it comes up with some weird adapter that i dont think will work. can someone please point me in the right direction? thankyou.
ORIGINAL: AL 01412
While the banana 4.0 plugs are decent, tamiya plugs are not upto the demands that brushless systems require. I have seen many tamiya plugs melt. Or at the least they get warped and then dont stay together properly.
I reccomend spending alittle extra cash and getting some pre-wired deans plug. then just cut off the plug on your ESC/battery and twist on the new plugs and tape.
you can buy a set like this on ebay. This ad has 2 ESC side and 3 battery side plugs.
http://www.ebay.com/itm/Deans-Connec...item2ebd6e2abb
Thanks again nitro. You're a big help. I ended up going with the deans plugs, they are working well. The truck is pretty quick with the 8.4 nimh. Just curious, I hear about people running 9.6 v nimh batteries in their Epx pro's? I didn't think the truck could handle it? What Would I need to eventually run a 9.6 nimh? I know i would need a ESC capable of an 8 cell, But would the stock motor be able to handle it? Do you think it would be worth it to upgrade to an 8 cell? I want the truck to be fast, but not uncontrollable.
ORIGINAL: AL 01412
So a 9.6v nimh is NO problem.
I think you would have to take the power lead from the fan on the ESC and wire it to run off the batt port on the reciever (because with a higher voltage battery the esc will send to much power to the fan, and the reciever will always give a constant voltage)
But other than powering the esc fan off the reciever, you dont have to make any changes.
Even a 2s lipo would be a bit faster than your 8.4v nimh. A 2s lipo is rated at 7.4v. but thats nominal voltage. peak voltage is 8.4v...and lipos will remain at peak voltage for much longer than a nimh pack (the power doesnt drop quickly like nimh packs)
Also, lipos are lighter. Less weight=more speed.
OH, its been awhile since ive had a caldera..but you also wanna think about how a 8cell nimh is gonna fit in the battery tray. You might have to trim the side of the tray for the 2 hump cells to fit.
