Redcat Please Make A Metal Spurgear For The Blackout
I've already had to replace not only the plastic Spurgear but the brass pinion gear as well. All in less than a month of light bashing. The replacement plastic and brass gears are already showing wear! Ive only ran about 5 battery packs in 2 weeks. It's not the gear mesh cause the Blackout is the only RC I own that gives me this problem. So please just release a metal spur gear. Sorry for the rant. It's just annoying. Thanks
I feel the same way. I've replaced three spur gears and five or six pinion gears in roughly two months of ownership. I'm trying to mod a volcano gear in there, but need a solution to keep the gear in place
That's pretty much what I did but instead of a spacer I used a dremel with a cutting wheel and moved the c clip back. I have the brushed version so I can only move the motor a little bit towards the center. I need to find a 30 tooth pinion and it should be good
Im pretty much done with this truck. Im about to get a bruched volcano and swipout the electronics. Put the brushless electronics into the volcano and the brushed into the blackout.
I like it but I doubt it could handle brushless power. Mine runs pretty well and takes a beating like no other, the main problem is the gears. I emailed Redcat and they have no plans on a metal spur gear. They should have designed it with a slipper clutch
I only run a 3s 5500mah in my blackout, we've been out many many times. And while I have broken parts I have had no issue with the spur gear. I did take out the 4wd parts and made it rear wheel. Lost the front dif, and dogs. Gains some speed out of it and still easy to control also stays a lot cooler through out the 3s discharge. I just don't feel that it is the plastic of the spur gear that is your problem. I can't help you I know but if you had a metal spur I still feel that it would still strip out.
