Caldera XB 10E
Caldera XB 10E
Hi guy,
I am new to Redcat and I have the Caldera. As I go through this buggy and purchase new parts, I need a little guidance on some of them. One of which is the location to attach the front and rear sway bar(s). No instructions can be found or videos of said items. Can any of you help. Picture are always worth a 1000 words.
You will need to remove the top screw from one of the shocks in order to get the sway bar in place. Then you will need to remove the two screws located on the bumper support which attaches to the top of the differential housing(under the shock tower). There is a slot behind where these two screws go that the straight part of the sway bar will fit into to. Next you will need to pop the caps onto the balls located on the a-arms. You may need to use something flat and thin like a flat head screw driver to leverage them on. The process is the same for both the front and back. I hope this helps! I'm ready to try and answer your next question when you get done.
I figured out the front sway bar. I finally got everything lubed and reassembled
