Redcat Volcano EXP Grinding Noise
Hello. bought my first, new Hobby grade RC. Redcat Racing Volcano EXP brushless. As I write this, I have had it just about 24 hours. Right out of the box it is making a horrible grinding noise & will barely move. Did some searching & youtubing & I think it is the gear mesh. I have had it apart twice now & I got it to where it seems ok when I move the spur gear or wheels by hand. However when I put it on the floor, it still has the same symptoms. I made a short Youtube
. Any help would be greatly appreciated
Well I had the trigger pulled all the way in the video. The battery was fully charged & I did program the ESC for LiPO. If that is the normal sound, then they should warn people.
If that is flat out something is wrong !
Things you could try .
Check voltage of battery with a voltmeter .
Check all motor wires are connected and also they are not kinked or damaged .
Throttle trim on transmitter .
Disengage the pinion from spur and see if it still happens .
Recalibrate transmitter .
Just so you are aware , in the video it seems you are trying to go very very slow ( just pulling the trigger ) .
This is the sort of sounds and jerky motion you get .
Makes me think it might be the trim or calibration.
Like seedygreenute said, transmitter trim or ESC calibration...possibly both.
If still having issues, call Redcat and explain everything to them.
