Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat tornado Differential
Old 09-26-2018 | 07:10 AM
Default Redcat tornado Differential
Does anyone know if there is a metal replacement for part# 02039 diff cup? Or a fancy trick to stop the metal center pin from breaking through the plastic guides?
Old 12-12-2018 | 08:32 AM
RustyUs's Avatar
Sounds to me that Redcat should have used a differential with four planet gears (Redcat calls them diff pinions) instead of just the two in the Volcano/Tornado platforms. I don't know of any metal diff housings to replace the Tornado's #02039.
Old 12-13-2018 | 06:56 AM
RustyUs's Avatar
Elaborating on post above. Some of the lower priced RCs will skimp on parts to bring down overall cost. During average use with moderate powered electronics, things hold up for a good amount of time. What is a good amount of time you ask? All depends on your trigger finger, driving style, temperatures, etc.
The Tornado/Volcano diff housing only provides a slot/groove for one set of (two) planet gears to apply forces on the sun gears. Nothing wrong with this...usually. It's just that when a person gets comfortable with stock power, then they put better batteries and/or high powered motor into their RC, the weak points begin to show up.
More durable designs (like pictured below) will have a differential with two sets of (four) planet gears to evenly distribute the forces on the sun gears...more cross pins, more planet gears = more power handling capability. There is always exceptions to this as well. The quality of the materials has to be taken into consideration.
More durable diff will have 2 cross pins and 4 planet gears.
