my car is slow?
my car is slow?
hi i have a tornado xp and it was fast until i adjusted everything and now it is just plain slow. it seems that there is no power going to the car. wich screw should i adjust for this problem? also what kind of new glow plug should i buy??
RE: my car is slow?
Toast , there have been a few good posts in here on Ebgine tunning you might want to go back and check.
Does the car Idle ?
What Fuel are you running ?
Is it smoking alot ?? I mean alot !!
Is it the OE glow plug ?
Sounds like the high speed adj. Thats the big one one the right that you can adjust if the body is one. Try turning it in about 1/8 turn at a time < clockwise> If it makes it worst just go the other direction. You really don't want to mess with to many other things until the car will at least rev up a little.
Does the car Idle ?
RE: my car is slow?
im really not sure ill try to adjust the high speed thing and ill try to find out if it is stuck in second gear as soon as i get my new a arm thx guys.
