no shifting...
Anyone know why one of my cars wont shift into 2nd? Do I adjust that screw on the clutch in or out? This is wierd. It wasn't shifting before so I put in another clutch and still won't shift[sm=confused.gif]
set screw on the 2 speed clutch counter clockwise shifts at lower rpm, clockwise shifts at higher rpm. do 90 degree's at a time and re-run the car and see, i have had no luck with the redcat's shifting, its either way too soon, not at all or stay stuck in 2nd gear. i put a new 2 speed clutch in too, very sporatic. My other nitro's with 2 speeds works great, think its a design flaw with the redcats.
On my Tornado XP the set screw that holds it on the shaft gets loose. When its loose it is shifting just not grabbing. Check to make sure that it is there and tight.
