Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Redcat Racing Support
 This may sound strange.....engine start problem >
Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Old 12-09-2006 | 07:32 PM
Default RE: This may sound strange.....engine start problem
you may have a air leak is it running or will it not start at all
Old 12-09-2006 | 07:36 PM
here is a simple way to tune your car i had mine running in about 10min after i fixed the air leak it had a air leak where the exhaust connects to the motor
ccw means turn the screw counter clockwise
cw means turn the screw clockwise
lsn-ccw richens and cw leans
hsn-cw leans and ccw richens
idle-cw opens the gap and ccw closes the gap
Set air gap of throttle 1.5 mm,(idle screw), HSN Cw til it bottoms out then 3 1/2 turn CCW. LSN Flush with the throttle housing + 1 turn cw. Try to start, will be runnin really rich, if it starts. Turn down idle speed, then adjust HSN cw til you have good acceleration to idle. if your idle speed rises, turn it down. May have to do a couple times. Last adjustment LSN, turn cw slowly til idle speed starts to rise. when it rises you're running lean, turn it CCW till idle speed just drops. Blip the throttle you should be acceleration ok with some smoke coming from the muffler.Lean the HSN 1/8 turn CW till your satisfied.
i also posted a pic of the motor i got the pic in faq thread
