Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
taking wheels off?
Old 12-15-2006 | 01:13 PM
Default taking wheels off?
im not real smart but i unscrewed the nut holding the wheel on and its still stuck? is it glued or anything? i thought it would just come off real easy. i dont wont to break anything.[sm=confused.gif]
Old 12-15-2006 | 01:50 PM
Default RE: taking wheels off?
just wiggle the wheel a little it will come off but once you take it off becareful not to lose the little metal rod that goes through the axle that is what turns the wheel
Old 12-15-2006 | 04:08 PM
abjones413's Avatar
It shouldn't have a pin. It should just have a 12mm hex and the wheel will come off with some wiggling. When reinstalling, don't overtighten the nut or it can make the inner axle bind inside the bearing. If that happens, no biggie. Just loosen the 2 grub screws on the axle itself and re-adjust...
Old 12-15-2006 | 10:34 PM
on my xp it has the little metal rod that zack is talkin about.
Old 12-15-2006 | 10:41 PM
pretty much all rc's with hex mounts have that small metal rod, sometimes its a little hard to take off the hex.
Old 12-17-2006 | 12:18 AM
abjones413's Avatar
VOLCANO SV, 12mm hex, no pin. Just 2 grub screws to hold it to the axle... I thought all the Cats shared this feature, even though a lot of other stuff differs, mounting wheels should be universal...
Old 12-17-2006 | 12:41 AM
there is no rod that slips in the hex nut?
Old 12-17-2006 | 12:43 AM
there is on the stx i forgot all about some of the others being different
