Redcat Racing Tornado Thread
#3001
TX
RE: Redcat Racing Tornado Thread
When I press the throttle sometimes the throttle servo will respond after a few seconds and sometimes when I turn the buggy on the wheels will point left but after I move the steering it works properly.The throttle servo is a Hitec HS-422 and the steering is a Hitec HS-425BB.
#3003
ORIGINAL: cirec
#3004
HiTec 125753 AGGRESSOR 2-CHANNEL AM 75 mhz RADIO NIB
Copy and paste at ebay...hopmeup had it for a little over $50 shipped. comes with a spare servo just in case...
#3006
ORIGINAL: gokartingbob455
ya know what...i miss ehroof.
I finally figured out a new pinion for my ep car. With a 10.8v 3300mah Nimh battery I'm pulling 42mph...Not too shabby....Just got my lipo charger today so tomorrow I'm going to try my 11.1v 5400mah lipo battery and see what I get. Gotta say I'm starting to like ep more then nitro...no plugs, blown engines, gas, tuning, mess or noise. Lots more expensive to start out but lots of fun without so many problems. But I still love that nitro roar...lol
#3007
KY
electric is like watching nascar with the sound off man. the only thing i have thats electric is a losi micro t. and i just got that for a rainy day and when im bored in the house.
#3008
#3010
Had a strange problem today. I already asked Ehroof and he said it's never happened to him so I wanted to know if anyone else has had a similar problem. While running my ep car that i put that traxxas velineon kit in the shaft that comes out of the motor (rotor) broke off at the motor case. Has anyone else ever broke that shaft on an electric motor or was mine maybe flawed? What would cause it? The crappy thing is the rotor is a $50 part and i can get the whole motor for around $75. For the extra $25 i might as well get a new one..lol
#3011
Traxxas are very good at honoring warranty claims, so talk to them first before you replace it. It was probably a flawed unit.
#3012
I've never held any rc company to their warranty. I figure as much as I change and as hard as I am on them it's my bad. I ended buying the replacement rotor and a new motor. At least next time I break something the car won't be down for a week..lol
#3013
AZ
ok so i just got my new (used) tornado today. its pretty sick. got it started and it ran like a beast. the guy lost two dogbones so i was goin rwd and it was still awesome. it would shift great. then it just quit shifting. im going to try to adjust the screw to change the shift point. i turn it out to make it shift earler, and turn the screw in to make it shift later right? if its not that what would it be? broken?
#3015
TX
The tornado take 6061 or 6022 dog bones:
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php/products_id/1711]http://allaboutfunhobbies.com/store/catalog/product_info.php/products_id/1711[/link]
#3016
yes you are correct. Turn the screw out to make it shift sooner. Less pressure on the spring and it catches the gear sooner.
#3017
anyone put a .18 or .21 OS engine on a tornado? i kind of want to go over the top with a .21..is there a link on here of which engine will be most compatible? i kno theres a difference with the short and long shafts. please help
#3018
TX
The O.S. 18 (not sure which o.s. 18) will fit with no mods, but with the .21 you will have to mod the chassis by drilling new holes and moving the engine as far back as possible. i know someone has fit a 21 engine on there car before.
#3019
Here stagga here is the os18 that fits. http://www3.towerhobbies.com/cgi-bin...&I=LXGGP7&P=ML
#3022
is the .18 o.s. engine leaps and bounds better than the stock one that comes on the tornado? (i do not have the SH.18) i think its a VX.18 or some crap. but i want something really ridiculous that has no business being on a 1/10 buggy lol! modifyin the chassis isn't a problem. if i mess up i can always order a new 1 lol.
oh and can i use my hpi clutch bell n gears on this?
#3023
AZ
you have to use the os crvx or something like that to be a direct fit. and they are way better than the vx. night and day difference i guess.
#3024
The OS 18cv-rx is the one that's a direct fit. The one with a (S) in the title has too short of a shaft. The os 18tz-tx will fit but you need a new manifold. The trx3.3 will fit too but you need a tmaxx header. The bigest easy swap would be the OS 21tm. It's a direct swap for the 3.3 so you should still just need the manifold and a 3.3 roto start or pullstart. The cv-rx is tons better then the stock engine but the tz-tx and the 3.3 are both faster then the cv-rx. That 21tm would rock but cost you around $350 with the engine, manifold, backplate and new filter.
#3025
CA
Hi,
My Tornado EPX motor stopped working suddenly, I am not sure what the problem is. I wish I knew more about troubleshooting.
Can anyone please suggest what would be a close replacement for the stock 540s motor.
Any help is greatly appreciated, this is my first RC vehicle and I just had it for a month.
Thank you.
Thank you.
