Redcat Racing Tornado Thread
#577
RE: Redcat Racing Tornado Thread
ok nother question[:@] does any one know a really good long lasting servo set up that has good preformance on the BB that does not get into the 100$? i was gunna go with futuba or hitech tell me what you think? preferably with metal gears
#578
TX
Hi tech is the best way to go, The programable hitech with the Karbonyte gears is a killer servo, I have one on my Hurricane and it kicks butt.
#579
futaba s3305 is great, i have it in my hurricane and its real strong. 35 bucks
or you can buy the 10$ one it works ok for a tornado, i used it for a while.
i also have a hi tect with the karbonite gears also both are good. 35 bucks should be the most you should have to pay.
#580
FL
I got this setup. http://www2.towerhobbies.com/cgi-bin...I=LXASX3**&P=7 So far, it works great. It's accurate and seems to have a good range. Check others that are similar, they may have a hi torque servo combo as well. My radios stunk and these really helped. No more of the quivering servos or inaccurate trim. Not bad for $50.00 bucks.
#581
I got a question on tires. Im going to the beach in about a month and I need a good suggestion on tires for the sand. Somthing that might grab better than the stock ones that come on it.
P.S. Just got my BB a week ago and it kicks butt..My Bro-n-law had a revo and he is jealous that mine keeps up with his..hahaha
#585
any one know a hex one way bearing that will fit the red cat back plate for the roto start>?? neeed quick reply please
that is not from redcat
#588
shock clips and they are to make the suspension stiffer, you slip them in above the spring, between the top spring holder and the top of the shock.
#590
ehroof, I got a question for you. I got the o.s.18cv-rx engine but it doesn't look like it will work. The shaft is to short so I can't put the flywheel on. Is there a threaded flywheel or how do i make this fit? Any help at all would be great.
#591
ORIGINAL: zack221
Here is a good motor that is faster than the stock one it is a direct fit just unbolt the stock one and put this one in.
http://www.rcsuperstore.com/product_p/osmg11860.htm
what do I need to make this engine work? The shaft is to short to attach the flywheel.
#592
I found out I needed a different crankshaft than the one that came on it. Another $40 dollars for a part I wouldn't need if people would just check what they are posting. So to all who want an O.S. engine go with the straight cv-rx not cv-rx(s). Thanks for the waste of money zack.
#593
Pro-Line Rear Velocity Dish T2/3 Yellow (2)
Pro-Line Front Velocity Dish 2.2" T2/3 Yellow (2)
Hey everyone this is my 3rd post. I ran into a problem with one of the rims busting at the hub.I have the tornado bb & was wondering if some could tell me if these rims will work or if there any good?If not could you suggest something.These rims are at tower hobbies.THANKS
#594
NY
Hey ehroof I bought the HPI clutch bell for my xp. I fried more spur gears with this than with the stock one. nI must have it in wrong. Cuold you post some pics of the order that the parts go in? If not could you help at all?[][&o] PLEASE
#596
IL
For a little more top end speed, will the 18T and 23T pinions work in the two-speed tranny? In stock form, my Tornado tops out at 48 mph.
#599
I got a question on the Tornado Shocks. Do they both have the alluminum cap on the bottom of them. If so then I busted on. Can someone help me on this. I just dont want to buy another pair if I dont need to.
