Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Tornado Thread
Old 02-25-2007, 07:48 PM
  #126
ehroof
Default RE: Redcat Racing Tornado Thread
the dinging is probably the bearings going bad in the clutch bell.
Old 02-25-2007, 08:06 PM
  #127
frekbynature2002
Mine started to ding, I removed the bearing to find that it started to come apart. Also, is there any other trans shafts I can use on the front wheels. I ran my car and one of the dog bones vanished form the front. I tried getting replacements from Redcat but they said to use another, don't carry the one listed in the manual. It is the 84mm shaft, the ones they said to buy is like 1/8" to long.
Old 02-25-2007, 08:15 PM
  #128
ehroof
you can use these:
http://www.redcatracing.com/itemdeta...p?partno=06047
Old 02-25-2007, 08:40 PM
  #129
archil
frekbynature2002,
So is the bell dinging normal? I am guessing it is simply the shoes engaging the bell.
Pete
Old 02-25-2007, 08:44 PM
  #130
frekbynature2002
At first mine wasn't dinging, then it started, thats when i found a bad bearing. Mine doesn't ding anymore, so I would say its not normal
Old 02-25-2007, 08:45 PM
  #131
frekbynature2002
Thanks, I hope I won't break those as fast. I run it hard every weekend
Old 02-25-2007, 09:11 PM
  #132
ehroof
you could email Dennis at clermontmotorsports.com and see if he carries them. they have to be better than the dogbones that come with it.
Old 02-25-2007, 09:45 PM
  #133
archil
ehroof,
Any idea what the part numbers are for either the redcat bearings or a third party replacement? The manual doesn't even have a picture of the clutch bell assembly, let alone a parts list.
thanks,
Pete
Old 02-25-2007, 09:50 PM
  #134
frekbynature2002
bearing PN I think are 02138 and 02139. not sure if this is correct
Old 02-26-2007, 06:05 AM
  #135
Chubbysdad
yes they are both bearings. 02139 are the smaller ones for the clutch bell
Old 02-26-2007, 12:54 PM
  #136
dude7422
hi go to your lhs any check out the bearings find one to fit
ORIGINAL: archil
ehroof,
thanks,
Pete
Old 02-26-2007, 05:29 PM
  #137
evlfkr
evlfkr's Avatar
Does anyone know where I can get front and rear aluminum carriers for the tornado xp? My rear carriers heat up and melt on the outside face. The bearings are fine, so thats not the problem.
Old 02-26-2007, 05:52 PM
  #138
dude7422
hi you dont have it shimed rite that is why it is hot
ORIGINAL: evlfkr
Old 02-26-2007, 07:32 PM
  #139
evlfkr
evlfkr's Avatar
What shims does it need? I'm not a newbie by no means, but I just don't see how it can be shimed! It could just be a defect in the part, its only the right rear that does it. Do you have a washer behind the drive pin? Just wondering, because mine dos'nt on either side, but it does have it on the inside! Its kinda like cat n mouse!
Old 02-28-2007, 12:36 PM
  #140
BOBCAT45
well i finally got my tornado xp monday, the weather wasnt very good so i decided to run it tuesday i had everything out and was fueling it up and wouldnt you no it ,it had a seam leak on the tank. boy was i poed. i took it apart and ran some epoxy around the seams and let it dry alnite . i just went out and filled it up and i guess i got it fixed,i fueled it up and it only took 5 pulls to start it! i ran 1 tank of fuel through it and put it up to windy out there. should i put some after run oil in it now because i was going to run it when my son gets home from school. what is the best temp to run these motors when breaking them in? i got mine up to 210 degrees on one fuel tank. i ran it 5 minutes and stopped to cool then ran a nother 5 minutes and let her cool, i done this 3 times. it says to do it for 3 tank fulls to break in the motor. does anyone have any suggestions or am i doing it rite? you guys sure have been helpful and i appreciate the suggestions.
BOBCAT
IF IT AINT BROKE, DONT FIX IT!
Old 02-28-2007, 05:24 PM
  #141
tyree
i just got my tornado xp i got it ready to break in the motor and it ran what i thought was a good idle and after about 5 min of idle it just stoped running ive been trying for an hour to get it restarted ive chanded glowplugs i took out the glow plug and put a paper towel over and pulled a few times to get exsess feul out and i tryed lifting up the rear wheels to see if it wasw the clutch spring and still nothing does any one have an idea what i can do to get it runnig
Old 02-28-2007, 05:27 PM
  #142
evlfkr
evlfkr's Avatar
Always use after run oil in the vx 18. The main bearings rust very quick! Just turn the high end needle out about 2 3/4 and let it run 3 to 4 tanks good and rich for break in.
Old 02-28-2007, 05:31 PM
  #143
evlfkr
evlfkr's Avatar
First turn the highend needle all the way in softly until it resists, back it out about 2 3/4 turns. Look at the low end make sure its flush, then check the batteries in your glow starter or power supply. If all is good it should run unless it is the clutch. Let me know! One more thing, check your head bolts and make sure they're tight!!
Old 02-28-2007, 05:53 PM
  #144
evlfkr
evlfkr's Avatar
Here's some pics of my xp. The body is final painting stage. "AS SMOOTH AS A BABY'S BUTT!!!"
This is with the mods listed on this forum on page 1. HPI clutch set up and rustler wheels with proline hole shot tires.
I think we need a 3 speed tranny 12-17-22 on the pinions and this thing would be a bullet!! lol
ID:	631748   Click image for larger version
Old 03-01-2007, 11:05 AM
  #145
frekbynature2002
I bought the hop hop parts for the front drive, universal trans shafts. How do the install. I took out the large bearing so they would set in place, but they seem to long, the upper a arm will not connect and since they are long, the shafts bind the wheels from turning. This was ordered by the PN listed in the book, is there something else I need to do or do I need the hub upgrades before they will fit.
Old 03-01-2007, 01:06 PM
  #146
ikillsqurrls
i got a tornado xp for my b-day and i was wondering if there is a certain fuel that works really well with a tornado
Old 03-01-2007, 01:12 PM
  #147
ikillsqurrls
i got tornado xp for my b-day and i was wondering if there is a fuel that works really well with the tornado
Old 03-01-2007, 01:43 PM
  #148
bluecaka69
bluecaka69's Avatar
ive always used Sidewinder 20% nitro and had no problems but theie is tons of great fuel out here i also here that o donnells fuel is great
Old 03-01-2007, 02:30 PM
  #149
ikillsqurrls
i got a tornado xp and i was wondering if there was a fuel that worked really well with a tornado
Old 03-01-2007, 02:31 PM
  #150
ikillsqurrls
k thanks blue caka
