Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
pull cord/starter cord
Old 03-18-2007 | 02:24 PM
Default pull cord/starter cord
my friend asked me to post this cause last time it worked. He said the cord when he tried to start the rc,it felt like it was caught up on something. So he left it alone but he was wonderin, why it was so hard to pull?
Old 03-18-2007 | 02:34 PM
Default RE: pull cord/starter cord
if it is flooded it will be very hard to pull, you have to take the plug out, turn it over, put a paper towel down and pull the starter with the car upside down, you will see all the fuel comeing out of the engine, you have to do this a few times, then put the plug back in. it should be much easier to start then.
Old 03-18-2007 | 02:36 PM
Sounds like a flooded engine. take the glow plug out and see if it is easyer to pull. if it is its just a flooded engine . turn it over and pull the rope to expel the fuel, the put it back in .
bobcat
Old 03-18-2007 | 02:39 PM
k i tell him that
Old 03-18-2007 | 04:42 PM
he did all that stuff and he said the cord is still hard to pull
Old 03-18-2007 | 06:37 PM
AllAboutFunHobbies's Avatar
Has it ever been started? If not some times the pinch can be so tight it feels like it's bound up, I ussually put about 3 drops of 3 in one oil or after run oil in the glow plug hole before I start a new engine so there's some lube to make it easier to pull and so it doesn't scratch the cylinder. Anyway, if it's been started it sounds like everyone said a flooded engine. Also take the pull start off and see if you can pull it vary carefully off the engine. Becarfull not to let it pop apart.
Old 03-19-2007 | 02:59 PM
its been started before so i guess he can look at this and fix it
Old 03-19-2007 | 04:06 PM
ok he said it works great now. it was a flooded engine.
thanks!!!
