Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
ENGINE KILLS AT FULL THROTTLE?
Old 04-12-2007 | 12:22 PM
Default ENGINE KILLS AT FULL THROTTLE?
My engine stall at full trottle. Suppose what the reason is? Tornado BB, 2 speed
Old 04-12-2007 | 12:37 PM
Default RE: ENGINE KILLS AT FULL THROTTLE?
Get on here and ask for ehroof he noes about them engines pretty good, he has helped me out a lot!
Bobcat
Old 04-12-2007 | 12:39 PM
most likely the high speed needle is too lean, you need to turn it counter clockwise like a 1/4 turn and see if it helps
Old 04-12-2007 | 01:37 PM
thanks but that didn't work! The temp is 225-230. Runs fine as long as I am not driving it around but once take off. Give it gas for a minute is stall.
Old 04-12-2007 | 01:58 PM
Murfreesboro HUH!!! that where my father is from!!!
if it's stalling when you give it full throttle from a stand still, it could be the low speed needle adjustment. open it a little see if that helps, check the fuel lines for trash or clog
tom
Old 04-12-2007 | 03:10 PM
that I haven't don't yet , thanks! will try after work
Old 04-12-2007 | 03:17 PM
tuning tips
http://www.rcuniverse.com/forum/m_5174647/tm.htm
Old 04-12-2007 | 07:57 PM
It takes off fine from start. While it is driving around it stalls. Full trottle, it stalls. Runs fine sitting still.
Old 04-12-2007 | 08:00 PM
it either overheating or the engine is shot, how is the compression?
Old 04-12-2007 | 09:19 PM
It has pinch but with that is I don't know how much it is supposed to have.
Old 04-12-2007 | 09:48 PM
You know what? I think I am just going to either get a os engine and also send this one back to redcat and get a new engine. This one has been annoying seince day one.
Old 04-13-2007 | 07:42 AM
MiniCwik's Avatar
LOL, man I would richen your HSN some more ... mine was doing that and I couldn't believe I had to richen it more, but when I did ... it got better.
That's all you can do man, is keep adjusting it in small increments until it gets better and then you know you are on the right track.
But an OS engine would be cool, but why not try and tune the one you have? On those same lines, I had a air leak, source was fuel tank and was why I had to keep richening things. Once I got that sealed up right, I could actually lean it.
Old 04-13-2007 | 01:47 PM
tuning videos
http://youtube.com/watch?v=oSmMzpZM_As
http://youtube.com/watch?v=BJFsJAxNoRg
Old 04-14-2007 | 10:44 AM
make sure the back-pressure line is connected and clean internaly
