Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Starter Box
Old 04-22-2007 | 01:59 PM
Default Starter Box
Will this Duratrax starter box from Tower hobbies work with the Tornado?
What starter box do you folks use?
http://www2.towerhobbies.com/cgi-bin...1&I=LB7137&P=N
Old 04-22-2007 | 02:16 PM
Default RE: Starter Box
If not a starter bos, what can you tell me about this item?
http://www.redcatracing.com/itemdeta...?partno=70111t
Do you remove the pull starter and attach some sort of gear to the back of the engine?
Old 04-22-2007 | 02:57 PM
You want a rotostarter, starter boxes are bulky and dont fit in your back pocket like a rotostart.
I got mine from this guy on ebay [link=http://cgi.ebay.com/Power-Battery-Starter-for-RC-Cars-Trucks-4X4-COMPLETE_W0QQitemZ170090342916QQihZ007QQcategoryZ3 4063QQcmdZViewItem]click here[/link]
Thats a complete kit with backplate that replaces the pullstart and a 7.2volt battery and charger... if you already have a 7.2 volt charger and battery check his store as he sells just the starter and backplate only also.
I am still waiting for my stuff to arrive form him but he has cutthroat prices and excellent service.
Old 04-22-2007 | 06:36 PM
I'll check it out.
It seems like most people prefer to use starter boxes. I already have the tower hobbies 12v sealed battery and the charger (used them for an electric starter for my planes) so all I'd need is the box itself. What style do you guys use?
Old 04-22-2007 | 08:01 PM
ofna but i dont use it much, dont like to have to carry it around not to mention the having a charged battery all the time deal.
Old 04-23-2007 | 11:56 AM
Well I ended up buying a starter box instead. I was done with yanking that pull start, so I decided to go big.
I got the Ofna 1/10 "true-start" universal box.
I still have a problem though.
Either the flywheel hole in the chassis is too small, or the flywheel doesn't stick down far enough. The rubber wheel on the starter box just barely touches the flywheel, but it makes contact with the sides of the chassis at the same time. What can I do? I can't see cutting the chassis, so my only other option is to use a smaller rubber wheel on the starter box. Has anyone else had this problem??
Old 04-23-2007 | 02:12 PM
myt ofna just fits but barely, you will need to open the chassis a little, if i go to using the box i will have to open it a little just to make it easy, or the smaller wheel, lol.
Old 04-23-2007 | 02:30 PM
I took my leatherman wave and filed down the edges of the flywheel opening in the chassis. I only took a little bit off, bascially just filed the corner of the opening flat to the the wheel enter the opening just a little more. Works like a champ now, no rubbing at all, but it is a very tight fit.
Old 04-23-2007 | 02:35 PM
nice bro, glad to hear it worked out for you!!! maybe i should start using mine.
