Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
spur gears
Old 05-03-2007 | 10:21 AM
Default spur gears
what are some other spur gears that are compatible with the tornado XP that I could get from the LHS HPI,Ofna,traxas,ect????
Old 05-03-2007 | 10:37 AM
hawk900's Avatar
Default RE: spur gears
only redcat spur gear will work,upgrade your clutch bell and spring and you wont strip spur gear
http://www.rcuniverse.com/forum/m_5132243/tm.htm
Old 05-03-2007 | 11:42 AM
thanks for the info.I finally got to run this car after owning it for about a year.just found the time to break it in monday ran it yesterday the car is actually pretty good for the money.it was tearing up the dirt lot then the gears went...
Old 05-03-2007 | 12:18 PM
you said that you have the two speed tranny? if not then you can use hpi part # A444. its a 44 tooth spur gear. thats what i use on my XL. It just has to be trimmed a bit and then its ready to rock and roll. but as hawk 900 said before, definately replace your clutchbell and spring. I recently did that and I cant believe the difference. Havent stripped one since! Hope this helps. Arlin.
Old 05-03-2007 | 06:02 PM
I'm going to try and get some parts this WE.I need to rid the buggy apart anyway.for some reason the steering servo wire got eaten and I am going to relocate the new wiring
