Clutch Slipping!!!Please Help!!!!!!!!!!
My clutch i think is slipping on the transmision the engine will slide and the car won't move when on the ground. OH yeah andwhat does the clutch spring do????????B/C IT IS broken and i took it out!!!!And i've been trying to drive it with it out so maybe thats the problem i don't know....Please Help.
Would this clutch spring work??? http://www2.towerhobbies.com/cgi-bin...?&I=LXNBD0&P=7
[sm=50_50.gif]i dont know man if that will work but it says 2 shoe so.....hey what cluch shoes have you in as well.it must be the stock spring ey
Yes that is more than likely the problem. Here is an updated spring and clutch shoes. You can use them both. http://www.clermontmotorsports.com/s...-spring/Detail
Its weird though i had the car running two days ago but after a little while it would just stop moving and then just rev unless i lifted off the ground but i do need a clutch spring since i don't have one. I think i will get one for like a couple bucks.
OK, bought the traxxas clutch shoes and spring for my tornado bb so it should be good after i get my new pull start, 2-speed, and 4wd working again i will probably post a video or some new pics in like a week or so.
bro, you cant use the traxxas shoes, only the spring. next time get the setup that clermont posted above this way you can use the cltuch shoes and spring.
i ordered them from towers but i checked and its at the warehouse already and they said i cannot cancel since they are about to ship out but its okay, Is the traxxas one any better than other clutch springs????
i have been using the 4146x spring, i am actually the one who came up with that fit but now that clermont found these other ones, its better to use the clutch spring and shoes instead of just the spring. order the clermont setup next time
WI
ORIGINAL: TannerReagan
why does that picture look like the spring is broke?.. shouldnt it have loops on both ends?..
CA
ORIGINAL: ENR_Kyle
