Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
cooling head
Old 06-07-2007 | 06:17 PM
Default cooling head
could anyone tell me how to get the head off my engine the head screws are stripped?
Old 06-07-2007 | 06:25 PM
AllAboutFunHobbies's Avatar
Default RE: cooling head
EWWWW, are you sure your using the right allen wrench? If the screws heads are stripped you might not be able to get it off. One thing you can try though is get a set of star hex drivers that you can gently tap into the hole in the screw head, but not sure how well that will work on the small hardened screws.
Old 06-07-2007 | 06:32 PM
how did u strip those screws ?
Old 06-07-2007 | 06:55 PM
i dont know its wierd they were fine one day and stripped the next i think my son got to it he loves engines of all sizes....
well. what you could do is get 4 allen wrenches that close to fit and jb weld them to the heads, let it sit overnigth and you will be able to turn them right out, there junk tho then.
Old 06-07-2007 | 07:32 PM
Drill the heads off.
Old 06-07-2007 | 07:57 PM
No No, bad idea, if the rest of the screw is stuck in the block and doesn't happen to come out for whatever reason then your realy up the sh-t creek without a paddle.
Old 06-07-2007 | 07:59 PM
i got them out i used a hacksaw and needle nose plers good as new.....
Old 06-07-2007 | 08:09 PM
LOL, that will work too I guess, at least you got them out.
Old 06-08-2007 | 02:57 PM
kool, though usually the best way 4 me to get stripped hex screws out is to use a slightly larger star shaped bit with an extension and use a hammer to tap it in and make a extremely tight fit, then us a wrench at the top of the extension and slowly twist it out, it works all the time but eventually the tip may break off inside the screw if you try it too many times with the same bit. thats how i do it, i dont know.[sm=72_72.gif]
Old 06-08-2007 | 04:49 PM
That's what i was getting at, lol, that's what I always do, but what the heck as long as they come out, no matter how you do it, lol.
Old 06-08-2007 | 05:04 PM
so nothings stripped?
