engine screws
i need to buy new spur gears for my transmission and i only have 2 screws holding in the engine. One of the holes is blocked b/c one screw came half way out and then snapped off so part of it is stuck inside and the other just fell out, anyone know what the item no. is for the engine screws???I need to buy some new ones and put lock-tite on them.
go to your local hardware/hobby store and let them match them up for you. you should be able to get that screw out if its sticking out of the engine a little, just use some needle nose ply's.
nope its not sticking out at all, i have some needle nose ply's i use them a lot but the screw is stuck in there. I may just have to buy one more screw so then i only have 3 out of 4 with locktite until i get new motor mount or something.
I had the same problem. Engine was mounted using only 2 screws, not four, and there were broke off screws in two of the holes. *quality control issue there*
I had to buy a couple of new blocks as nothing could ge the broken screws out.
didn't cost much, was just a ball ache
