Tech Question..HELP!
Not sure what it is called but I have a Tornado BB and one of the front rod looking things that make the tire turn is missing. So I only have 3 tires turning. What is it and what is it called so I can get a new one. Also where could I get one?
Thnx, Scott
Thnx, Scott
NY
you need the 80 mm dog bones, the manual lists the wrong ones, you can get them here
http://allaboutfunhobbies.com/store/...roducts_id=452
or here
http://www.clermontmotorsports.com/s...MM*2PCS/Detail
or here
Awesome. Ill get some now. Also I was just running it and my second gear wont engage. What would that be. I hate being new but im glad we have forums like this.
Thanks guys!
Thanks guys!
NY
We all have that problem, I can't get my second gear to engage on my Tornado or Tsunami, I am still trying to figure that one out. I have the same problem w/ my Jato, they just don't like to hit second gear, lol. Try adjusting the little set screw on the second gear of the tranny, it's supposed to help but not always. Just don't loosen it too much or the screw and the little spring will fall out & you'll have an even bigger problem. Let me knbow if that helps.
FL
Those 06022's will be a little long. Either you can put them up front and just not run the ball screws in as far and adjust the steering a bit or put them in the back and move those to the front. When I got mine I had the same problem and asked the exact question... LOL
GA
some times the clutch comes loose on the shaft and rotates freely. make sure it is tight. also make sure the tab springs out and works freely
xp, xl ,lightning, xtm xt2 owner
tom
tom
